93-98 T100s All T100 trucks
97 t100 hard cold start
Old Jan 27, 2019 | 02:26 PM
Fed684's Avatar
I have a 97 t100 3.4. 167k. Starts hard after it sits more than an hour or so. Once running it runs and idles fine. New fuel filter plugs and wires. Didnt seem to make a difference hitting it with a shot of starter fluid. Seems to catch slightly faster if i cycle to key3-4 times before turning it over. Still takes 1-2 5-10 second cranks. Fuel pressure test next? Thanks in advance for any ideas!
Old Feb 10, 2019 | 08:26 AM
jskijoe's Avatar
Sounds like a fuel issue. The pump shouldn't even run until you're cranking since I don't think it has a pre-pressurizing stage in the on position. Maybe it's losing it's pressure while its sitting and takes a while to re prime itself. bad injector potentially if there are no external leaks.
Old Feb 10, 2019 | 10:48 AM
75w90mantraN's Avatar
Check for leaks at fuel filter since lines were opened. One way to lose pressure.
Good batt charge? Quick to find with a multimeter. Test before the first crank of the day, not after engine's already been warmed up. Verify clean and tight posts and terminals.
Does it ever just make a click sound when you turn the key to START/RUN? Meaning, it doesn't crank?
Injectors, typically it would run with performance issues. Would consider if nothing else.
brycetryce
Nov 30, 2018 07:24 AM
ajetski07
Nov 27, 2017 12:31 PM
jmc88runner
Jun 18, 2015 03:39 PM
mtb83201
Nov 16, 2013 06:42 PM
andykrow
Sep 21, 2010 09:14 PM
