PDA
View Full Version : 93-98 T100s
Pages : 1 [2] 3 4 5
  1. 98 SR5 T100 Crank no Spark bad ECU/ECM
  2. questions from new owner
  3. T100/Tundra Parts and Manuals
  4. 97 T100 - Vibrating Rattle While In 4WD (Accelerating)
  5. t100 legal issues w/ rear bumper option
  6. *grill guard (aka deer zapper) for t100
  7. 96 T100 SAS- the Mutant Turtle build
  8. SR5 Cluster swap into a Base 4cyl T-100 ?
  9. CEL P0141 Code wont go away 3RZ 1996
  10. Painting Chrome T100 Bumper
  11. New (to me) T100 a few days away
  12. 4wd system question
  13. Shudder at Constant Speed- what the hell is it?!
  14. T100 SAS options
  15. 1995 t100 idle popping
  16. Tips on installing KYB Gas-A-Shocks?
  17. Discontinued fuel line/s Help!!
  18. engine diaphram
  19. Door wont close! Help!
  20. 97 t-100
  21. 96 T100 5vzfe wont start throwing p1300 code
  22. 94 t100 speedometer cable
  23. Steering relay bar
  24. 96 t100 performance 5vz build
  25. clutch pedal too low why??
  26. Towing enclosed trailer
  27. 97 T100 Strange Shudder/vibration
  28. 1996 t100 3.4 sr5 problem
  29. 1994 T100 RWD 3.0L Standard
  30. front wheel bearing kit? 96 fit a 98
  31. '95 T-100 brake light, blower motor, etc.
  32. 1995 vs 1997
  33. Torque converter spline 20 or 26 96 5vz 4wd ext
  34. Engine running rough after changing spark plugs
  35. Voltage Running High, Killing Alternators
  36. 4wd light staying on while in 2wd
  37. Resurrection.
  38. Power Steering questions
  39. Automatic transmission slip
  40. need help finding LED tailights
  41. help with electrical issues
  42. T100 with 1st gen Tundra bed
  43. new to the forum
  44. 93 T100 rear differential replacement
  45. T 100 topper for Tundra
  46. T100 transmission swap
  47. 1996 T100 SR5 Break Lights
  48. Will a 98 FSM apply to my 97?
  49. Driveline nose on acceleration only
  50. 97 toyota T100 OBD 11 code p1700 & p1700pd
  51. T100 clutch help
  52. Ran across a cream puff
  53. Help, Truck died while driving, won't start
  54. Best Radiator
  55. Drive train noise, need help
  56. Winter starting issue?
  57. DIFFERENT 4x4 Problem, guaranteed or money back
  58. T100 Engine Swap Ideas
  59. Troubleshooter needed please help!!
  60. Toyota t100 2wd leveling lift kit
  61. Brake Shoes/Springs
  62. Intro and how to get over 300k
  63. What year Pickup or 4runner Manual hubs fit T100
  64. T100 rear sliding window width.
  65. Joining the T-100 club, anything I should be aware of?
  66. 3.0L Power loss when Check Engine Light comes on
  67. rear decal strip removal
  68. 5VZFE assembly hel
  69. half axle torque spec? 95 T100
  70. a/C switch rarely working. help?!
  71. Installed interior lights
  72. 98' t100 been driving it the last 14 years love my T.
  73. 1996 T100 4 WD issues
  74. 96 T100 3.4 - Where does this part go??
  75. 97 T100 Napa replacement cv joint/drive axle issue
  76. Fuel filter location and flexible fuel couplings...
  77. New engine? I need one
  78. Light bar mounts???
  79. 95 automatic T100 - I'm stumped!
  80. "ECT PWR" Non-existent in these trucks?
  81. Idler arm broken
  82. Cant get my emergency brakes to hold truck
  83. Have you had a replacement windshield installed?
  84. Bed Swap Question
  85. '95 T100 lurching on uphills?
  86. 98 T100 brake/marker/ tail lights not working
  87. 2000rpm Idle
  88. 93 T100 interchangeable with 95 T100?
  89. t100 2.7l 5speed stall issue
  90. t100 5 speed conversion
  91. Fuel pump relay???
  92. What does a new exhaust system cost?
  93. Whats it worth?
  94. Beating a dead horse??
  95. Painting steel wheels - what color?
  96. 97 Toyota T100 check engine light from (bad words)
  97. 95 T100 no power to obd11 fuse
  98. Toyota T100 power unloading
  99. Help! Need Replacement Leaf Spring Bushings
  100. 5VZ-FE - Need advice.
  101. Toyota T100 Modifications
  102. I'm new! Need Help/Ideas
  103. the ghost no start
  104. T100 OWNERS- Need your help please!
  105. power steering problem
  106. inspection plate
  107. T100 backup lights on all the time
  108. Spark Plug electrode broke
  109. First T100 troubleshooting help
  110. 1997 T100 front/upstream oxygen sensor part number?
  111. Bad Steering Box?
  112. need a 95 t100 engine with wiring harness
  113. 1996 T100 pulls to the right
  114. another t100 clutch problem
  115. Finally! A winch bumper for the T100!!!
  116. Alignment Issues
  117. 96 T100 diesel swap
  118. Custom skid plate needed for T100
  119. T100 bed liner for free
  120. All pro spray in bed liner
  121. 2.7 intermittent engine misfire
  122. $1800.00 to replace time belt, plugs and VC gaskets?
  123. T100 Rear Ended - Insurance Wants to Total
  124. Are T-100's with the 3.4 V6 as reliable as the classic 22RE
  125. Engine Install Question
  126. Replaced headgaskets now running hot
  127. Gas Tank Leaking
  128. '98 T-100 Swap Question
  129. T-100 Hood Won't Open
  130. TOTAL CHAOS lift question
  131. 1 qt. to much of oil, truck is not running good
  132. keep an eye out for a T100 being parted out for me-
  133. T100 4cly 5spd 2wd speedo very confused
  134. T100 lift!!! Help!!
  135. 96 3.4 sr5
  136. where to buy 98 steering damper
  137. Ground connections? 94 T100
  138. T100 4wd
  139. bucket to split bench in extended cab 97
  140. 97 t100 exhaust
  141. 1996 T100 3.4 Swap QUESTION
  142. Tacoma/4Runner/T100 R150F Compatibility
  143. Oil Pressure
  144. Body lift
  145. Loose Parking Brake?
  146. Control Arm Bushings, Need Advice
  147. Rear differential rebuild
  148. A04A Gear code on door, ratio
  149. 4X4 Problems 1995 T100
  150. New here with a question
  151. T100 Snorkel
  152. fuel mileage help
  153. 1993 3VZE Knocking Diagnosis
  154. Gear ratio A05A 1994 T100 DX
  155. T100 Skidplates
  156. Rear bumper
  157. t100 wiring harness issues
  158. Help finding bilstein shocks for a 2in lifted Toyota T100
  159. Kill Switch install help?
  160. HELP brakes pulsing
  161. Airbag Light Does Not Come On At Startup
  162. Lifting 95 t100 reg cab 2wd base/compatible ct arms
  163. Engine Conversion
  164. Quick ADD/4WD question from newbie
  165. Hard brake pedal when cold
  166. Hard brake pedal
  167. What other seats fit the T100?
  168. 96 Toyota T100 3.4 P0302
  169. Shocks for a Daily Driver T100 with a 2in lift
  170. 98 supercharged, how to make more powerful?
  171. HELP 1997 Toyota T100 3.4L 4x4
  172. HELP LIFTING MY 1997 TOYOTA T100 3.4l 4WD
  173. 1997 Toyota T100 3.4L 4x4 Ext Cab
  174. HELP 1997 Toyota T100 3.4L 4x4
  175. Best way to lift the rear of a truck under $300
  176. Sway bar removal?
  177. Poor heat, stuck open thermostat?
  178. 86bedlesstoy's T100 build
  179. Load Sensing Valve/Brake ?
  180. 3.4 missing on #2 but has spark? injector?
  181. Shaking/Vibration from stop
  182. Good OE replacement muffler for 3.4 T100
  183. T100 Transmission - 1st gear popping out
  184. Fuel gauge stuck on full
  185. Valve cover gaskets replaced, leaking again
  186. Regearing a T100
  187. 94 t100 sr5 lift question
  188. Lifting
  189. Need Help! Cab Mount Squeaking!
  190. T100 the good, the bad, the ugly
  191. Crank bolt torque specs
  192. 97 t100 4x4 flex plate
  193. T100 5spd 4wd vs. 1st gen tundra 4wd 5vzfe 5spd
  194. 97 t100 4x4 3.4 liter starting problems
  195. 98 t100 sas
  196. Electrical Issue?
  197. Cleanest t100 I have seen
  198. 96 t 100
  199. 96 T100 4x4 front axle questions
  200. T100 4wd not working
  201. CA model T100 differences?
  202. Need engine
  203. 1996 T100 front end sag
  204. 1996 T100, 3.4L 5VZ consumes double its fuel stipulated
  205. 96 3.4 4x4 won't start, battery starter OK
  206. Replaced my radiator today
  207. T100 picture thread?
  208. nerf bars for T100 from 2000 tundra?
  209. pass side front wheel greesse everywhere popping grinding noise help
  210. What to Replace When Replacing Timing Belt?
  211. Wierd brake problem
  212. Lifting my 1997 Toyota T100 4wd 3.4L Extended Cab
  213. Rear Bumper
  214. Lifting my 1997 Toyota T100 4wd 3.4L Extended Cab
  215. 96 t100 won't start
  216. Lifting my 1997 Toyota T100 4wd 3.4L Extended Cab
  217. Replacing A/C Compressor
  218. 98 T100 will not start
  219. Vapor Pressure Sensor
  220. Timing belt time
  221. Toyota T100 SAS spring questions
  222. Toyota T100 SAS Gear Inquiry
  223. 1998 Toyota hilux 2wd 1uzfe gearbox conversion
  224. My 95 5spd is having a hard time shifting into 1st & 2nd
  225. 1998 t100 hub removal
  226. 3.4L Valvetrain noise and T-belt
  227. 97 T100 (trouble starting after sitting in sun)
  228. Better Brake Calipers & Hoses than Stock?
  229. How to Adjust idle on 3.0 v6 t100
  230. New t100 owner
  231. T100 Replacement Tailgate
  232. Lifts questions t100 4wd
  233. Broke my frigin fan blade!
  234. The backseat and a baby
  235. 1997 T100 Leaf spring mounting issue
  236. 97 T100 Overheating after HG repair
  237. 96 Toyota T100 SR5 SAS
  238. power loss
  239. Battery/Alternator light coming on
  240. Introduction And Some Quesitons
  241. stuck in park
  242. Interchangeable fenders??
  243. Bucket seats for T100
  244. Riddle, wrapped in a mystery
  245. Lift kits
  246. High Idle Problem NOT IAC
  247. New T100 Owner!
  248. IAC valve test. NEED HELP ASAP
  249. T100 for sale.
  250. Subwoofer box in T100?
