93-98 T100s All T100 trucks
Old Mar 30, 2016, 11:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Engine Guides
Print Wikipost
What to Replace When Replacing Timing Belt?
Old Jul 25, 2013 | 12:51 PM
8lugnuts's Avatar
My old T-100 has 133K on it and I have never replaced the timing belt. I know it was replaced by the dealer around 50K when it was recalled for the head gasket problem years ago. I'm gonna buy the kit that NAPA sells which includes the tensioner, idler pulley, water pump, and belt and all the related gaskets. I'm replacing all three engine belts too as I believe they are original, hoses are good(newer).
Do you think there is anything else that should be replaced while I am doing this job?
Old Jul 25, 2013 | 01:28 PM
rworegon's Avatar
Have you looked at AirCabinMan's excellent kit(s) on eBay?
Crank bolt (FSM lists as non-replaceable) and thermostat/t-stat gasket for sure. Cam and crank seals if they are showing signs of leaks.
Remember, 217 ft-lbs when torquing down the crank bolt.
Old Jul 25, 2013 | 01:37 PM
CJM's Avatar
CJM
I did aircabinmans kit about 2 weeks ago now, I chose to do the kit with just the waterpump, tensioner, idler belt and associated gaskets. I also put new radiator hoses on and changed the t-stat.
All of the parts in the kit were OEM or very good parts (koyo for example).
Old Jul 25, 2013 | 02:02 PM
Team420's Avatar
This ^
May even want to replace the cam/crank seals regardless of signs of leakage while youre in there....
Old Jul 25, 2013 | 07:59 PM
8lugnuts's Avatar
Is there a particular reason for replacing the crank bolt? I've got a genuine yota 1996 T100 FSM and cannot find any reference to replacing it or anything that states "non replaceable". There *is* a part # for it.
Does anyone know what the Camshaft Tensioner Hydraulic Assy is for and whether or not it should be replaced(what to look for). I can't find a reference to it in the timing belt section of my FSM.
Old Jul 25, 2013 | 08:13 PM
rworegon's Avatar
My 95 FSM for the Tacoma is like yours.....it makes no mention. However, I have seen later 5vz-fe FSMs spec it as non-reusable (about $10 from the dealer) and the torque spec is 217 ft-lbs.
Toyota updated the spec from 184 ft-lbs to 217 ft-lbs to address issues of the crank bolt coming loose and, at the same time, the crank bolt became non-reusable in the FSM. Fun reading.
The tensioner keeps proper tension on the timing belt. It's in the timing belt inspection section of my FSM. Many of us change it whenever doing the timing belt.
Old Jul 25, 2013 | 08:32 PM
Bullet22r's Avatar
Rockauto sells an Aisin kit i used a couple weeks back on my sienna and everything was oem, Mitsuboshi timing belt, Koyo bearings, and water pump of course was Aisin, and if you search they have a 5% discount code online.
Old Jul 25, 2013 | 08:39 PM
rworegon's Avatar
The crank bolt could probably be re-used if some locktite was applied to the threads.
Old Jul 25, 2013 | 08:40 PM
Team420's Avatar
Originally Posted by 8lugnuts
[SIZE="2"][COLOR="Cyan"]Is there a particular reason for replacing the crank bolt?
I personally wouldnt bother with replacing it. But for $10.... may as well....
Old Jul 26, 2013 | 06:47 PM
8lugnuts's Avatar
Thanks to everyone for your input. I found that some timing belt "kits" include the Camshaft Tensioner Hydraulic Assembly(Napa's definition) and some do not. Napa's kit does not include it but one from Advance Auto does(Dayco kit...."Timing Belt Actuator" is what they call it). The NAPA branded part alone is $78, $49 for the Dayco at Advance. . I trust Napa parts more than the big chain discount stores(been burned too many times).
Old Jul 26, 2013 | 07:28 PM
rworegon's Avatar
Toyota dealers sell the hydraulic tensioner for about $50 also.
Buy this http://www.ebay.com/itm/Toyota-TIMING-BELT-WATER-PUMP-KIT-Genuine-OEM-Parts-4-Runner-Truck-3-4L-V6-/180729034728?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a144a37e8&vxp=mtr#ht_1818wt_721 (OEM parts, Toyota packaging) or http://www.ebay.com/itm/Toyota-V6-Trucks-TIMING-BELT-WATER-PUMP-KIT-w-Hydraulic-Ten-Genuine-OEM-Parts-/190580749105?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c5f7f7331&vxp=mtr#ht_1742wt_679 or http://www.ebay.com/itm/Toyota-3-4L-V6-Complete-Timing-Belt-Water-Pump-Kit-/190521450224?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2c5bf69ef0#ht_1711wt_679 (OEM brands, non-Toyota packaging) depending on what you want to change out.
Many of us find it's hard-to-beat the price for these top quality kits.
Old Jul 27, 2013 | 07:48 PM
8lugnuts's Avatar
I agree, I should have had someone get one of these kits for me since I do not have a eBay account nor paypal. I already got everything I needed today from Napa. It was a lot more $$$ than these kits you showed me. I appreciate the info though.
Old Jul 28, 2013 | 05:13 AM
rworegon's Avatar
Do you need a tutorial? If so, member skjos did a good one.
Good luck!
Old Jul 28, 2013 | 11:52 AM
8lugnuts's Avatar
I could do it if my work schedule was not so busy and I had a place to work on it. I don't have a garage or barn, heck I've got almost 10acres and don't even have a shady tree to work under! well at least not near the house. Last year I did both front axles, on my back, in the driveway, on jack stands...never again. About 3 weeks ago I did both front calipers on the same d/w and fried like an egg in my old griswold skillet. I am having someone else do this job plus a bunch of other stuff that's way overdue, I don't have the time or patience right now plus I'm doing stuff on my old Jeep, it ain't a happy week for me unless I get a fist of grease and a face full of grit at least once
Old Aug 13, 2013 | 07:40 AM
FW-739's Avatar
I have re-used the crank bolt without any problems
Old Aug 16, 2013 | 05:50 AM
t100 noob's Avatar
lol
could always just buy a total build - rebuild kit, 650 bucks has everything you need includoing forged pistons and pushrods and rockers, i just wish somebody made performance heads for these engines the 5vz-fe is a great little thing i love it, id love it more with boost.
Old Feb 9, 2014 | 07:37 AM
psill68's Avatar
I too used the non-oem kit from Aircabinman. All good parts (aisin, mitsuboshi, etc.). Interesting that most of those parts were made in some place called "Usa."
Old Feb 10, 2014 | 02:24 PM
rworegon's Avatar
Actually, many are the same exact parts you could have bought in Toyota boxes for more dough.
Old Feb 10, 2014 | 03:41 PM
CJM's Avatar
CJM
5,000 miles so far on mine, belt wasnt even bad either just replaced for GP since according to previous owner was done about 140k ago.
voiddweller
19
May 2, 2016 09:10 PM
stagger_lee
Mar 29, 2016 06:27 PM
layifioren
10
Jul 6, 2015 02:26 PM
marcusSRG
Jun 27, 2015 07:13 AM
infinityisfive
Jun 16, 2015 06:51 PM
