93-98 T100s All T100 trucks
98 supercharged, how to make more powerful?
Old Jan 21, 2014 | 04:50 PM
charged98t100's Avatar
I have a 98 3.4 v6 and its supercharged. I wanna make it more powerful but I dont wanna dig too deep.˟I have aftermarket manifolds as well. Cold air intake? No genius when it comes to this stuff.
Old Jan 21, 2014 | 05:22 PM
millball's Avatar
How much more power do you want?
How long would you like it to make this increased power before it blows up??
No long lasting power mods are ever cheap.
You could go nitrous.
Old Jan 21, 2014 | 05:35 PM
Nothing too extreme. Nitrous seems to be a bit much. Haha. I've read about the programmers n all I've really found is that theyre junk. Same with the power chips. Is that true?
Old Jan 21, 2014 | 06:04 PM
JasonYota's Avatar
I believe you can change the pulley on your charger do get more boost. Maybe a meth injection kit after that. Or a good 75 shot of nitrous
Old Jan 21, 2014 | 06:17 PM
Just make it smaller right? And would that make my engine wear faster or the s/c wear faster?
Old Jan 21, 2014 | 06:34 PM
250000_yota's Avatar
The most common way to boost the output of the supercharged 3.4's is through this kit here:
http://urdusa.com/Fuel-Upgrades-URD-...duct_info.html
Quite a few guys on here are running this kit. Once I get the money, I'll be adding it to my truck too.
Old Jan 22, 2014 | 04:40 AM
JasonYota's Avatar
If your worried about extra wear on the engine why do you want to push more power out of it?
Old Jan 22, 2014 | 06:41 AM
Greg_Canada's Avatar
Do you have a tune / bigger injectors yet? If not, that is the first thing you need to do. You will gain 30-40hp and will actually cause less stress on the engine.
Old Jan 22, 2014 | 07:33 AM
MaK92-4RnR's Avatar
never heard of anyone complain about the power from a supercharged 3.4, but Ok.
You have aftermarket "manifolds" which makes zero sense, because manifolds are a stock part. I think you mean headers?
You could add a cold air intake, but then I wouldn't take it offroad, unless it has a enclosed casing.
7th injector would be nice, but I mean, its not gonna be a race car with just a 7th injector.
I'd keep it how it is.
Old Jan 22, 2014 | 02:46 PM
CJM's Avatar
CJM
Simple: Remove engine and put 350 chevy V8 in. Instant power...
Old Jan 22, 2014 | 03:16 PM
MaK92-4RnR's Avatar
Remove the 3.4 for a 350? yikes. Even I wouldn't do that for a 302, and I own mustangs. lol
Old Jan 23, 2014 | 04:02 PM
CJM's Avatar
CJM
Well if he wants more power its gonna make it with a V8.
Old Jan 24, 2014 | 05:03 AM
BamZipPow's Avatar
Upgrade the injectors, cooler plugs, and maybe some higher octane gas.
What plugs are you running now?
What octane are you running now?
Intercooler might make a difference...just not sure what yer output numbers are now. Have you had yer T-100 spec'd at a dyno shop? Post up the numbers. I'm guessing unless you already have the 7th injector that yer running lean at the top end and have a good chance of killing yer engine.
What size of tires do you have on there now? Stock gearing? Auto or manual transmission? If it's an auto, do you know if the valve body/torque converter was modified/upgraded? If not, then you probably burned up some of yer clutches already. Give John a buzz over at Import Performance Transmission and he'll give you the real skinny on what needs to happen.
http://www.importperformancetrans.com/index.php
Old Jan 27, 2014 | 10:23 PM
86bedlesstoy's Avatar
you could be a FIRST to install a Tundra v8 or Sequoia V8.. Keep it Metric standards and TOYOTA made..
Old Jan 28, 2014 | 03:49 PM
vital22re's Avatar
totally a bro
There is no replacement for displacement. Having said that, unless you're ready to drop a crap ton of money into building the motor to handle more boost and the hardware/software to control the fuel, then don't. You can just add methanol injection for cheaper then the 7th injector kit. However you'll have to constantly buy methanol or approved fuel. The 7th injector kit has everything you'd need and will just pull gas from the tank. It will also have a really basic tuning ability. You will still need to buy a A/F ratio guage to monitor the ratio and to aid with the tuning.
Jeffreynmandy
Jul 18, 2015 08:26 AM
mengquis
Jul 13, 2015 10:39 AM
cars-guy
Jul 11, 2015 07:51 PM
Cplmike
Jul 8, 2015 08:47 PM
skoti89
Jul 8, 2015 12:05 AM
