93-98 T100s All T100 trucks
Valve cover gaskets replaced, leaking again
Old Nov 25, 2013 | 05:00 AM
powdermnky007's Avatar
I replaced my valve cover gaskets with a nice felpro setup about 1-2 years ago. Now they are excessively leaking again. Can I just tighten the bolts? If so, how much? 1/4 turn 1/2 turn?
Thank you.
Old Nov 25, 2013 | 12:56 PM
BamZipPow's Avatar
Did you originally put in some sealant at the cam corners? I guess it would depend on how hard the gasket is or if it's cracked. It would be best to replace it as tightening has limited success as the gasket has already shrunk.
Old Nov 25, 2013 | 01:05 PM
I had a local shop do it, so I'm not sure if they used sealant or not. They probably didn't. You know how that goes...
Old Nov 25, 2013 | 03:36 PM
CJM's Avatar
CJM
I replaced them 2x and gave up as they werent leaking bad. I suppose I could try for a third time using some grease perhaps on the gasket to perhaps promote better sealing but I gave up.
If they are leaking take it back.
jennygirl
Nov 17, 2015 11:24 AM
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
serenity03k64
Jun 27, 2015 07:59 AM
crazypaint
Jun 23, 2015 03:27 AM
