93-98 T100s All T100 trucks
Driveline nose on acceleration only
Old Jan 31, 2016 | 06:20 PM
Nate Bell's Avatar
OK folks, I need some help.
95 T-100 with 238K miles. I have a pretty loud whine that begins around 50mph and gets louder at higher speeds. It stops immediately when I let off accelerator and is completely silent when coasting.
I've replaced hanger bearing, all u-joints have been repeatedly checked etc.
The only thing I can think of is about a year ago, the rear differential got pretty low on oil and I've been thinking that the front pinion bearing might be bad.
I pulled the axles and 3rd member and can't find anything that shows wear although pinion bearing does show a little bit of discoloration.
Everything feels tight and looks good otherwise.
Any ideas before I just give up and bolt it back together till something fails?
Old Feb 16, 2016 | 05:02 AM
Otika999's Avatar
I am having the same issue with the truck i just bought yesterday. Did you ever figure out exactly what was causing it.
Connor G
Apr 7, 2016 06:04 PM
rluhrs15
Jan 7, 2016 06:52 PM
Ifoundyoda
Dec 6, 2015 02:29 PM
voiddweller
Dec 2, 2015 03:12 PM
mj928
Nov 7, 2015 10:45 PM
