93-98 T100s All T100 trucks
Shocks for a Daily Driver T100 with a 2in lift
Old Jan 23, 2014 | 05:06 AM
jaretstuff's Avatar
Hi I am a newbie to lifting trucks. I have about 350-400 dollars for a lift kit for my T100 and my shocs.
Here is where the questions start
What model Bilsteins are the cheapest for a 2in lift
Can I use any shock for a tundra rig on my T.
I need help on this one.
Old Jan 23, 2014 | 05:20 AM
jaretstuff's Avatar
What length bilstein is needed for a 2in lift. All the bilsteins I can find are for stock ride heighth
Old Jan 23, 2014 | 09:47 AM
CJM's Avatar
CJM
What kinda lift? Body lift you dont need longer shocks, suspension lift is harder to find shocks for with the T100. Rancho has some stuff that might work, you need too look up the stock sizes and then match up some longer ones. I run bilstein HD shocks on mine, it rides like a truck-not soft!
Front my torsions are cranked about an inch and rear I have about 1-1.5" of lift with an extra leaf. No issues on my stock shocks tho.
Old Jan 23, 2014 | 09:50 AM
250000_yota's Avatar
You can't use a tundra shock on the t100. Different suspensions all together.
Here are the part numbers I've found for bilstein's for my truck. I have a 1.5 inch ball joint spacer lift and 2 inch lift shackles in the rear.
Shock part numbers
Front
Bilstein 24-185745
Collapsed: 11.67
Extended: 17.95
Rear
Bilstein 24-185752
Collapsed: 16.06
Extended: 25.63
Old Jan 23, 2014 | 12:08 PM
jaretstuff's Avatar
Shock part numbers
Front
Bilstein 24-185745
Collapsed: 11.67
Extended: 17.95
Rear
Bilstein 24-185752
Collapsed: 16.06
Extended: 25.63
Thank you
mskalmus
May 28, 2017 07:51 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
Sep 4, 2015 09:27 AM
jgallo1
Jul 22, 2015 04:21 AM
Coreyr384
Jul 10, 2015 11:13 AM
