93-98 T100s All T100 trucks
Toyota T100 SAS spring questions
Old Jun 19, 2013 | 07:04 AM
541-Mudder's Avatar
I am doing an SAS on my 96 Toyota T100 SR5 3.4L V6. I am going to run a set of Dana 60's with 5.13 gears and 37's. The truck itself weighs roughly 4000lb. I am thinking roughly 7 inches of lift in total in order to allow for the springs to settle and still maintain clearance.
Here is my dilemma... I am not sure what springs to run. I have heard good and bad things about Alcan but they seem to be the best price for custom springs. I have only heard good things about Atlas spring but their prices were high. I have looked at AllPro and Trailgear but I have heard mixed things about these as well. I haven't been able to find Marlin springs but I have heard good things about them.
What do you guys think or suggest?
Old Jun 19, 2013 | 07:17 AM
SCToy's Avatar
Marlin uses all pro springs now if i recall.
I'd talk with Alcan if you want to get a specific amount of lift and matched front and rear.
Old Jun 19, 2013 | 10:21 PM
Zpd426's Avatar
National and Deaver are a couple others to check out as far as custom springs go.
good luck! Post some pics when your done!
Old Jun 21, 2013 | 12:01 PM
541-Mudder's Avatar
I have talked to Alcan and Atlas and they both are rather expensive. I have found a set of front leafs made by Dave's Off Road Performance and from what I have heard they are pretty good springs. But I may bight the bullet and go full custom springs.
Old Aug 6, 2014 | 12:00 PM
PuddleJumper55's Avatar
What size springs did you end up using? How tall is she/pics?
Old Aug 7, 2014 | 06:34 AM
541-Mudder's Avatar
I ended up going with atlas spring company for the rear. They are 5" lift flex springs. For the front I went with Dave's Off Road Performance springs. His spring don't have a lift specification. Rather, you select a set based off of what tire size you want to run, i.e. 37+ tires or 37- tires. I started a build thread on Marlin Crawler last year. Almost every one of my posts have pictures. Here is the link to my build. Enjoy...
http://board.marlincrawler.com/index.php?topic=94747.0
GreenLion
Jun 7, 2021 10:49 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
duckhead
Jul 17, 2015 04:45 AM
Niameyrider
Jun 25, 2015 05:50 AM
