93-98 T100s All T100 trucks
Fuel pump relay???
Old Mar 26, 2015 | 02:51 PM
ej1618's Avatar
Fuel pump relay???
So I'm still working on this 1996 t100, heads are in timing is set. Vacuum lines are routed and ready to go. The problem is when I hit the key I get zero fuel, so I thought bad fuel pump. Pulled the bed and dropped the tank to gain access, checked the wires for power with the key on and nothing. So I made a jumper wire and voila the pump is alive. This tells me that there has to be a relay or fuse bad. I've checked the part online so I can identify it but can't find anything that looks similar. So my question is where is the fuel pump relay located? Any help with this is greatly appreciated..
Old Apr 2, 2015 | 10:57 AM
BamZipPow's Avatar
Fuel pump relay aka Circuit Opening Relay should be located behind the right kick panel about midway up.
Old Aug 30, 2015 | 02:03 PM
Mike31313's Avatar
Dud you fix it
Did you find the problem. I'm having the same issue
Old Sep 7, 2015 | 08:09 AM
BamZipPow's Avatar
Wink
Did you check yer fuses? The 15A EFI fuse is the one that sends power to the fuel pump via the Circuit Opening Relay (aka fuel pump relay). The other one is the 7.5A IGN fuse that sends the control power to the relay. Are you sure yer fuel pump is working?
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
