93-98 T100s All T100 trucks
96 3.4 4x4 won't start, battery starter OK
Old 08-31-2013, 03:54 PM
spikester62's Avatar
96 3.4 ext. cab with 230,000 miles, 3.4 L. Drove it downtown and back days ago, and 2 hours later, wouldn't start (no noise from the starter). Took battery and starter to auto store. Battery recharged and good. Starter was tested = good. Put both back in, still won't start (no noise from the starter). So replaced the starter relay. Still won't start (no noise from the starter). Checked the 2 fusable links and they look fine. What could this be? Thanks
Old 08-31-2013, 04:02 PM
other details
Ignition switch rebuilt about a year ago. Does not seem to be the problem. (Dash lights etc. behave as normal) Automatic and no problems with shifter. Tried starting in Park and N. Same result.
Old 08-31-2013, 04:04 PM
wyoming9's Avatar
Red face
Do you have a Multimeter ?/
Check voltage from positive battery terminal to engine block.
Auto or manual check your safety switches ??
Battery terminals clean and tight not cracked
Did the wire fall off the starter solenoid or did you not get it on correct when you had the starter out
One has to start some place and check one step at a time
Old 08-31-2013, 04:47 PM
Kiroshu's Avatar
Ignition fuse...?
Old 08-31-2013, 05:23 PM
BamZipPow's Avatar
Shoot some video of yer situation and post it.
Who rebuilt the ignition switch? Why did it need to be rebuilt?
Did you trace fer power at the neutral safety switch?
Old 08-31-2013, 05:30 PM
rworegon's Avatar
Worn out starter contacts inside the starter?
Old 08-31-2013, 08:54 PM
totally a bro
Staff
vital22re's Avatar
Check to see if you're getting 12 to the starter trigger/signal wire. *have someone turn key while you have wire and a ground probed*
If no power then see if your neutral safety switch is faulty, it won't kick your starter relay *ground signal I think*
There are two big fuses 100amp and 40 amp that send power to starter relay for the starter
You should also get power to st2 of the ignition switch that goes to the starter relay via a black wire.
Good luck
Old 09-01-2013, 07:42 PM
Thanks for the help!
Turned out to be the starter. Got voltage at starter, took it in (it had been tested as "good" days earlier) and they replaced for free under warranty. Total cost, 27 bucks for the relay that I didn't need. I will never again believe a "starter test" 100%.
Crazychris1871
06-27-2016 10:38 AM
Sandman
07-23-2015 08:15 PM
aciorba23
06-29-2015 04:18 PM
newzingo
06-24-2015 01:50 PM
Corey
06-10-2002 04:23 AM
Quick Reply: 96 3.4 4x4 won't start, battery starter OK
