check engine light on with Key out/off...won't start
1990 4runner 22re
Just finished timing chain/head gasket. Truck would start before procedure. Now the check engine light is faintly on when the key is off and out of the ignition, it goes off when I put the key in.
The engine turns over but won't catch.
1, Are these two issues related?
2. Ideas to get started? air flow maybe?
other info:
Fuel in the fuel rail.
good spark
new plugs and wires, new distributor/rotor
new starter
I'm certain the timing chain is on correctly
moving the distributor around to adjust timing didn't help
other info:
good spark
new starter
The check engine light being illuminated with the ignition off and key removed is strange, I don't know what to make of that.
On the no start, I just had my head machined and changed my headgasket, etc. Couple things I checked and re-checked on mine: That ground wire in the loom that feeds the injectors, do you have that connected, it should be right on one of those bolts between the #2 and #3 intake runners. There is a ground connected on the power steering pump bracket, and then there is a ground from firewall to the back of the head, I believe on the lifting hook.
If it still won't start, can you verify that at TDC, the rotor is pointing pretty much at #1 spark plug?
jpsfj60
May 6, 2012 04:42 AM
toy-ota4runner
Nov 4, 2011 01:41 PM
Damion69
Jul 1, 2010 04:18 PM
