93-98 T100s All T100 trucks
3.4L Swap/Engine Sources
Old Oct 31, 2023 | 02:39 PM
PaulieWalnuts's Avatar
Im entertaining the idea of swapping my 3.0 out for a 3.4, the 3.0 needs a new head gasket (again) this will be the 3rd one with only 200K miles on it, the first one was replaced under a recall in 1999, rather than spend $2600 on rebuilding the 3.0 already in there and burning out another head gasket, i figured why not throw in a 3.4, my question is i see wildly different pricing options on available engines out there, ranging from $5000-6000 for a Jasper or other Toyota reman certified engine, to some for $1500-$2000 on ebay. I have no doubt the Jasper engine would be great but at $5000+ and $2500 for the install it is cost prohibitive, are the $1500 engines on ebay any good or too much of a risk? This project makes sense financially with an engine price of $2000 or less but not at $4000-5000+ but only if they're not junk. Any other good, cheap reliable sources for replacement engines that won't break the bank?
Old Nov 1, 2023 | 07:17 AM
BBQ Tables's Avatar
I've replaced 6+ used engines from car-part dot com and had good luck each time. Just pull a valve cover before you pick it up and put a timing belt / water pump on it.
Trappeur54
3.4 Swaps
49
Mar 29, 2014 11:52 AM
IthacaBill
Engine Swaps
Dec 30, 2013 09:50 AM
Cyberman
Jan 4, 2013 04:54 PM
pbballa
Jun 4, 2008 07:05 PM
jkirk
Aug 2, 2003 01:24 AM
