93-98 T100s All T100 trucks
Does 370,000k Scare You?
Old May 6, 2009 | 02:53 PM
mr_dewkey's Avatar
I'm still looking for my T-100...
I found one that looks almost perfect, but it has 370,000kms (=230,000 mi). I would be much more comfortable in the 200k-250k range. I'm thinking I could replace the engine in the near future if needed. I really want one of these trucks, and I've been searching and waiting for over a year. I've never really had a high mileage vehicle, and this one is up there for sure.
What sort of odometer readings are your T-100's showing?
If I go to look at it I'll be sure to watch for leaks, burning oil, loose steering, cv noises, and shift through all the gears... anything else? Maybe get a full mechanical inspection?
FYI it's a '98 ex-cab 4x4 SR5 V6 Manual.
Old May 6, 2009 | 03:02 PM
ozziesironmanoffroad's Avatar
how much?
Old May 6, 2009 | 06:31 PM
Froggy93's Avatar
I got 133,000 miles on my 93 and it's still going strong. If memory serves me correctly 98 was the last year they were made. I've seen 4runners and other toyota vehicles go way more than 230,000 miles.
Old May 6, 2009 | 06:58 PM
jason191918's Avatar
does 370,000k mean 370,000 kilometers or 370,000,000 miles?
Old May 6, 2009 | 07:43 PM
aviator's Avatar
I've got almost 350000km on my 94 with the 3.0 and it is still running strong... no driveline issues or anything else either except for needing new rear leafs... they are worn out now lol... the only things you need to check for sure are when was the timing belt last done [if has been changed on schedule it is just past due +/-], check the body for rusty panels [no big deal they are relatively easy and cheap to change], check the condition of the frame [should be fine but if it spent a lot of time in very salty areas without being anti-rust sprayed it might have issues], and of course the saddles might need to be "refreshed" with new cloth/foam but that is really up to you.
Old May 6, 2009 | 10:19 PM
scuba's Avatar
Well its a 3.4 so you could probably get another 50k outta the motor..
I know the T100's are rare..But why not just get a Tundra ?
Old May 6, 2009 | 10:23 PM
stormin94's Avatar
Well, if nothing has broken yet, it should be good... But I'd definitely double check everything mechanical, and don't expect too much out of it. 230,000 doesn't scare me too much, since I've got 216,000, I'm almost there. But buying it from someone else would have me leary. My advice, Keep looking. Unless it's just too good of a deal.
Old May 7, 2009 | 07:16 AM
BamZipPow's Avatar
I got my 98 T100 when it had 307k miles on it. Just like anything else, you'll need to give it a good look over...take it to a shop and have them take some readings on the motor. I got mine fer $2200. With a little work this gem polished right up...
Old May 7, 2009 | 08:42 AM
mr_dewkey's Avatar
As I said "370,000kms =230,000 mi". So yeah 370 thousand kilometers or 37 billion centimeters
How much?
> It's $5,400 CAD (Canadian Dollars). That's about $4,600 USD.
Why not just get a Tundra?
> I want the 3.4L V6.
>I don't really want a V8. If I went V8 I might go for a Ford F-150 Supercrew (a comparable Tundra is WAY more $$$).
> I love the styling of the T-100 and the size.
> I bought a 2007 Tacoma (double cab, Manual, TRD) new, but I'm losing it in a divorce. I also need to refinance and buy my house for like an extra $100k. Suffice to say funds are short. My budget is <$10k.
> I was kind of thinking about 3.4L Taco's or 4Runners, but I would like to tow ~3,000lbs to 4,000lbs a few times a year (towing a dedicated offroader). T-100 should be better for this.
I'm going to take a look at it. Thanks for the ideas so far! I think corrosion is not an issue, but I'll look close. It's dry here in Alberta.
Old May 7, 2009 | 01:01 PM
aviator's Avatar
Sorry to hear about the split... I'd say put a little sand in the gear box but 1. you'd probably end up paying to fix it and 2. that should never happen to a yota no matter what...
check the T100 close she might not always have been an Alta. truck... a lotta gewphs from the rock brought their trucks with them during the boom...
Old May 10, 2009 | 09:54 AM
mr_dewkey's Avatar
I wouldn't even spit on that truck, it's beautiful It's black, with the 5 foot bed.
lol!
Old Jun 3, 2009 | 05:24 PM
t100bobo's Avatar
i got 225,000 and its a beast on 36's
Old Jun 3, 2009 | 07:10 PM
aviator's Avatar
Nice Iltus Mr. D Is that a Vdub original or a bomber "kit" built? Have you rewired the dash yet?
Old Jun 3, 2009 | 08:33 PM
RobD's Avatar
lol!
Want me to "steal" it for you?
Old Jun 3, 2009 | 08:47 PM
twitchee2's Avatar
We have had a 96 4runner sense day one. its well over 240,000 miles and doesnt burn a drop of oil. Its not been getting the millage it should but im willing to bet thats due to air filter/maf cleaning and maybe the o2 but that engine and drive train is dead sound.
Old Jun 3, 2009 | 09:19 PM
turboboost's Avatar
Mileage doesn't scare me at all with these trucks. It all depends how well it's been maintained.
Old Jun 26, 2009 | 11:06 AM
mrvoodoodaddy69's Avatar
3.4 310,000 miles of abuse on mine and still runs like a charm. has developed an oil leak around the valve covers up until that used no oil. i also have a 4runner with the 3.0 183,000 on it use about a quart ever 3000 miles, but still runs very well. but it will get the 3,4 swap as soon as i get the parts rounded up
Old Jun 26, 2009 | 11:38 AM
CRafferty's Avatar
Originally Posted by mrvoodoodaddy69
.. up until that used no oil...
That's amazing! You didn't have oil?! lol
Old Jul 14, 2009 | 03:17 PM
mr_dewkey's Avatar
Bombardier Iltis, ex-DND. I just rolled over 62,000 kms on a weekend camping trip.
I replaced the flasher box, and changed the wire to the fuel pump when I relocated it up front... Everything works perfectly. Why would I "rewire the dash"? Is this about some rumor that it will catch on fire spontaneously or something? It has a map light, 3 gauges (volt/oil pres/temp), 3 dummy lights, a heater/hazard switch, push button ignition, and integrated speedo/fuel gauge cluster. Why would I rewire that?
I think there are a lot of rumors and mis-information floating around about the Iltis. I don't mind as long as it keeps the parts and vehicles cheap.
p.s. Still looking for a T-100. I almost bought a 2003 Tundra, but the deal was too good to be true. It was in 3 accidents and 1 was a total loss.
Old Jul 14, 2009 | 03:29 PM
bigt's Avatar
do the itis have dual lockers?
i want to get a ex canadian army truck.. thats kewl
atleast my samurai is kinda a army truck lol
