93-98 T100s All T100 trucks
Clutch drops to floor
Old Feb 4, 2011 | 04:54 PM
godonr's Avatar
On a '96 T100 with 4cyl. Recently changed cracked clutch sub assy and everything was fine until the other day. The clutch shifts normally and then starts to return slowly until the next time it's depressed, it just drops to the floor. I can pull it back up with my foot and it will work awhile before doing it again. Slave was replaced before clutch bracket and I see no signs of leaking anywhere. Master is orig with 126K on it. I'm not losing fluid but it does have a strange sound like sucking air when pedal is depressed! Any ideas. Hope it's not the pressure plate, heard you have to pull the engine on this model to replace the clutch. Anyone have any first hand knowledge of that?
Old Feb 5, 2011 | 07:59 AM
eric-the-red's Avatar
Sounds like the internal master cylinder seal has gone, so when you push the pedal the fluid just goes past the piston instead of getting pushed out. Rebuilt ones are not very expensive so I would try that first.
Old Feb 5, 2011 | 08:20 AM
godonr's Avatar
got one and fingers crossed that solves it! thanks
Old Feb 5, 2011 | 08:40 AM
polycrack's Avatar
yup sounds like the master for the clutch is bypassings due to worn seals
Old Feb 5, 2011 | 09:34 AM
blake.nemitz's Avatar
possibly the push pull spring on the top of the pedal?
Old Feb 5, 2011 | 09:52 AM
godonr's Avatar
Yeah... that spring is a booger to get in but I did use new bearings and all when I did the sub assy change so I'm not thinking it's the prob... but, never say never is my motto on stuff like this. thanks for the input
Old Feb 5, 2011 | 12:21 PM
Blue Steel's Avatar
subscribed. hey guys so literally two mins ago im driving down the street when my clutch goes to the floor and wont come back. i had to perfect shift and start in second all the way home not to mention make an amazing amount of unecesary turns at red lights to avoid stopping (even ran a red to get home ) so yeah could this be my MC aswell? thanks for the help guys much appreciated. again the clutch pedal is stuck to the floor i can pull it up with me hand thats about it.
Old Feb 5, 2011 | 12:30 PM
godonr's Avatar
blue steel - my clutch still functions when pulled back up and acts like normal for a bit. haven't had a chance to install new mc to confirm it's the problem yet. Yours sure sounds like it too
Old Feb 5, 2011 | 07:14 PM
BamZipPow's Avatar
I would say yer master cylinder is dorked cause of the clutch bracket changed the angle/pressure on the shaft. I'm sure it's worn out yer master cylinder...time to replace it.
Old Feb 8, 2011 | 06:49 PM
Blue Steel's Avatar
soooo whats going on guys? i replaced my slave and then accidently broke a line while trying to screw it back into the new slave so lost my entire reservoir onto my hand while trying to install this POS. yeah waiting for that line from the stealership. should be here tomorrow... godonr whats going on with your problem???
Old Feb 8, 2011 | 06:54 PM
Kiroshu's Avatar
Theres not very many parts on the clutch system. You said slave was new and you did bleed the system after install. No leaking Fluid. Master Cylinder<----- Cheap part they go bad its the nature of the beast. Replace.
Old Feb 9, 2011 | 12:09 PM
Blue Steel's Avatar
yeah fixed my problem. got that line from toyota today put that and the slave in, bled it and it feels like the day i put my new clutch in =D
Old Feb 9, 2011 | 08:39 PM
Blue Steel's Avatar
ok so do people normally replace the CMC when the replace the slave? cause after bleeding it and driving it around for a while it wasn't as hot as it was.... it wasn't slipping into the gears as smoothly. little bit of resistance there which would lead me to believe that the clutch isn't engaging all the way. so air in the lines or new CMC? i'll bleed again and see... thoughts? thanks.
SubiKing
Aug 21, 2021 03:57 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
