93-98 T100s All T100 trucks
Bad shifter?
Old May 5, 2011 | 10:01 PM
mjbskwim's Avatar
Bad shifter?
OK I just got this 97 T100 with the 5 speed.Nicest driving POS I have ever been duped into.
Runs great.Drives great,even with the bald Hankook 285s.Even better with the new street tires.Has a few little problems but nothing I can't handle.Brakes,rear seals,fan switch,loose idler arm.....basics.
So the problem I need info on is the shifting part.Well first gear.It falls out unless I hold it in place.Then it bumps and grinds,and sometimes just violently BANGS it out.
And yes I changed the little cup and nylon doodad on the shifter plate.Seems worse as I the day goes on.
Marlin has a HD shift fork,but since it's aluminum,it would break instead of bend,no?
Do I need to pull the tranny and change syncros?
Any help would be great
Thanks for answering my first question on here.
Old May 5, 2011 | 10:24 PM
justin_4runner's Avatar
sounds like something inside the trans like syncros or bad shift forks.
Old May 5, 2011 | 10:41 PM
mjbskwim's Avatar
Now I read something about the clutch petal mounting cracks and this may have something to do with it...??
And isn't it possible for the fork to at least deform before breaking,causing this?
Thanks
Old May 5, 2011 | 10:47 PM
vital22re's Avatar
totally a bro
Sounds like an internal problem to me. Bad syncros for sure though.
Old May 5, 2011 | 10:55 PM
mjbskwim's Avatar
So vital22re,who's the toyota guru up here in the NW that you would have do it?
Or is it something I could do w/o too many extra specialty tools?
I'm over in Sequim,btw
Old May 5, 2011 | 11:28 PM
BamZipPow's Avatar
Did you check the fluid level and what type of gear oil that's in it?
Old May 6, 2011 | 12:29 PM
mjbskwim's Avatar
Level was good but no idea what fluid is in it.Going to the dealer to get idler arm parts,I see what they recomend.
Thanks again
Old May 6, 2011 | 12:57 PM
Lumpy's Avatar
The syncro would cause it to grind...shouldn't make it pop out though. It the fork or forks are bad/bent/not right these would cause what your noticing.
As far as taking it apart...I've never had one open. It's scary in there!
Old May 6, 2011 | 05:01 PM
mjbskwim's Avatar
The fact that it does it more as it gets warmer leads me to believe the fork.
But y'all never heard of the clutch petal bracket having anything to do with this?
Yeah I'm skeered about it too. That's what professionals are for
Old May 6, 2011 | 05:13 PM
Lumpy's Avatar
The clutch bracket cracking will cause hard shifting it won't cause it to come out of first gear. 1st might be on it's way out as well...
Old May 7, 2011 | 06:23 AM
mjbskwim's Avatar
Might as well get a rebuild kit fro Marlin and do the whole thing.
I'll change oil and see how much debris is in there too.
Old Jul 28, 2011 | 09:52 AM
mjbskwim's Avatar
For got to come back.
As it turned out,the bolt that holds the fork on the shaft was rubbing the case.Otherwise it would have come out and rattled though the gears.The fork was also a little worn.
Since I don't have a press,I had the local transmission shop do the work.And since most of the cost was to be labor taking it out,I had them just rebuild the whole thing
With a new clutch it all came to about $2.37 short of $2k
Now to the rear axle problems...
he's gone
7
Dec 3, 2019 07:08 AM
rusty904
Mar 27, 2017 05:20 PM
Motomonty
Aug 9, 2015 05:53 PM
Tonetrk
Aug 6, 2015 10:06 AM
Tonetrk
Aug 3, 2015 08:47 PM
