93-98 T100s All T100 trucks
97 t-100 check engine on
Old Jul 22, 2012 | 06:28 PM
t-100-truck -driver's Avatar
Hi,folks,I am new to the site.I had my check engine light to come on,so I took it to the local auto parts store and they put an obd 11 scanner on it and the codes 450 and 441 come up.They told me that it could be several things such as the pressure sensor switch malfunction or incorrect purge flow/IT'S funny ,because they won't sure where they are. Can you guys help me on this/Maybe a diagram/
Old Jul 22, 2012 | 06:39 PM
rworegon's Avatar
Use the FSM (Factory Service Manual) link in my sig to get a manual close to your rig. And, start searching this site.
http://www.ncttora.com/fsm/T-100/199...T100%20FSM.pdf
For a '02 4Runner, but it will help get you started:
http://www.ncttora.com/fsm/1996/SIL/...zfe/parloc.pdf
P0441 Evaporative Emission Control System Incorrect Purge Flow:
http://www.ncttora.com/fsm/1996/SIL/...e/cip0441p.pdf
P0450 Evaporative Emission Control System Pressure Sensor Malfunction:
http://www.ncttora.com/fsm/1996/SIL/...e/cip0450p.pdf
Old Jul 24, 2012 | 05:13 PM
Hey RWOREGON, THANKS ALOT .For some reason I am having trouble opening the first pdf file,but what you have given me will help alot.
Old Jul 24, 2012 | 05:26 PM
rworegon's Avatar
The first link takes several minutes to download. It's the entire manual in PDF.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
razorman8669
Jul 12, 2015 12:13 PM
