93-98 T100s All T100 trucks
Strange Intermittent Problem
Old Dec 11, 2012 | 03:57 PM
canu49's Avatar
I own a 93 T100 that I bought new. It's got 256K miles on it now. For the last 3 or 4 years it's had a problem that no one's been able to pin down yet. About once a year, the truck will not start. It's usually after the engine has warmed up and the truck turned off. I wait about 30 minutes and it cranks and runs fine. It's done this about 4 times, usually a year apart. Also, when I start the truck it will crank, then lope for a couple of seconds then catch up and run fine. Also, if I run up to about 45 and let off the gas, it will bump. I only drive the truck about 10 miles round trip, 5 days a week and rarely on weekends. I don't get a check engine light when the problems occur. I've changed fuel filters, cleaned throttle body and replaced plugs, distributor cap and rotor. This really has me stumped.
Old Dec 11, 2012 | 04:04 PM
maachine's Avatar
could be your starter relay or your starter with the no start issue. and the "bump" you are talking about, could be slack in the drive line. like bad u joints or slack in the rear differential gears
Old Dec 20, 2012 | 05:32 AM
DanBates2002's Avatar
Hey I've got this same problem, but more frequently. Say, I drive to work, 8 hrs later it will start fine and bring me home. However if I drive to a restaurant and stay for about an one and a half it will not start for another few hours. I'd love if we could get to the bottom of this!
Stats: 94 t100 sr-5 auto trans 4x4, 226000 miles
Old Dec 20, 2012 | 05:40 AM
j2the-e's Avatar
Happens once a year is pretty much impossible to diagnose. My suspicion would be the temp sensor for the ecu. Engine has 2 temp sensors, one for the gauge and one for the ecu. So make sure you get the right one if you do it. Another possibility is a leaky injector, but that would be more likely to be more frequent.
Old Dec 20, 2012 | 12:21 PM
canu49's Avatar
I'm changing the temp sensor this weekend. I'll let you know.
Old Dec 25, 2012 | 06:04 AM
maachine's Avatar
i misread your first post, sounds like the starter turns but the engine wont start right?
Old Dec 25, 2012 | 06:18 AM
brianh699's Avatar
There is a third temp sensor, but it's actually a switch for the cold start injector, if it's out of spec the cold start injector can fire on a warm engine flooding it.
Old Dec 25, 2012 | 11:46 AM
canu49's Avatar
not an intermittent problem anymore. Won't start at all now. Had a temp sensor so I changed it and no help. Did some troubleshooting and looks like the fuel pump is dead. I jumpered B+ to FP in the test connector with the key on and it didn't make a sound.
Old Dec 25, 2012 | 12:23 PM
maachine's Avatar
check all your fuses first before you start buying parts
Old Dec 26, 2012 | 12:09 AM
canu49's Avatar
I checked voltage at B+ before I jumpered it. According to the schematic, I was putting 12 volts directly to the pump and bypassing all relays also. Checked fuses earlier.
Old Dec 26, 2012 | 06:43 AM
Dang, it sounds like this issue is really get out of hand! I'm on the verge of having a local shop drop a new engine in. Like most, I depend on my truck!
montanatruck
Feb 26, 2017 07:07 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
colinmil
Jul 6, 2015 04:03 PM
