93-98 T100s All T100 trucks
cv axles
Old Aug 12, 2011 | 01:44 PM
findley87's Avatar
cv axles
i'm lookin to find out what cv axles will interchange into my 1995 t100. i have some manual hubs i'm putting in and i broke the cv's so i'm gonna replace them at the same time. i have some out of a 90 model v6 pickup just wondering if they fit
Old Aug 12, 2011 | 01:46 PM
xxxtreme22r's Avatar
pickup/4runner's wont work too short.
Toyota Part 43430-34010
OEM Toyota SHAFT ASSY, FR DRIVE
Toyota Camry
1992.08-1996.06; 6cyl 3.0L; LE; ; ; 1992.08-1996.06; 6cyl 3.0L; SE; ; ;
1992.08-1996.06; 6cyl 3.0L; CE; ; ; 1992.08-1996.06; 6cyl 3.0L; XLE; ; ;
1992.08-1996.06; 4cyl 2.2L; CE; ; ; 1992.08-1996.06; 4cyl 2.2L; XLE; ; ;
1992.08-1996.06; 4cyl 2.2L; LE; ; ; 1992.08-1996.06; 6cyl 3.0L; SE; SED; ;
1992.08-1996.06; 6cyl 3.0L; LE; WG; ; 1992.08-1996.06; 4cyl 2.2L; DX; CP; ;
1992.08-1996.06; 4cyl 2.2L; LE; CP; ; 1992.08-1996.06; 4cyl 2.2L; DX; SED; ;
1992.08-1996.06; 4cyl 2.2L; LE; SED; ; 1992.08-1996.06; 4cyl 2.2L; XLE; SED; ;
1992.08-1996.06; 6cyl 3.0L; DX; SED; ; 1992.08-1996.06; 6cyl 3.0L; XLE; SED; ;
1992.08-1996.06; 6cyl 3.0L; LE; SED; ;
Toyota T100
1992.08-1996.06; 6cyl 3.4L; DLX; ; ; 1992.08-1996.06; 6cyl 3.4L; SR5; ; ;
1992.08-1996.06; 6cyl 3.0L; STD; ; ; 1992.08-1996.06; 6cyl 3.0L; SR5; ;
Old Aug 12, 2011 | 01:53 PM
findley87's Avatar
well alright i broke the right one. if i lock the actuator in 4wd position will it at least lock the left side in where it will pull
Old Aug 12, 2011 | 01:58 PM
not with an open diff it wont.
Old Aug 12, 2011 | 02:08 PM
findley87's Avatar
thanks i know where a few camry's are
Old Aug 12, 2011 | 03:31 PM
NicCantDecide's Avatar
...why not go to AutoZone and pick one up for $60?
Old Aug 12, 2011 | 06:29 PM
a junk yard one would probably be less then $20 and alot of people would rath an OEM in which is $419 new. .
If your gonna grab one from a camry, make sure you notice the build dates on them as well. By the looks of it they are 1993-1996 model year, but toyota gets a little funky with model years.
Old Aug 13, 2011 | 03:41 AM
findley87's Avatar
I rather have OEM set plus I can get them from pull apart for 23 a piece
Old Aug 13, 2011 | 03:51 AM
Anyone find it interesting that the Camry has the same CV's?
Old Aug 13, 2011 | 04:40 AM
findley87's Avatar
I would have never thought they would be the same
Old Aug 13, 2011 | 04:53 AM
To tell you the truth I'd rather pull them from a camry as you know most likely they weren't beat on.
I Just ran the part numbers for the early pickups and 4runners same thing. Some cars and stuff listed as well.
Old Aug 13, 2011 | 05:44 AM
findley87's Avatar
I was wondering to what truck I need to look for to get some 4.56 gears out of
Old Aug 13, 2011 | 05:59 AM
In general 4.56's were usually put into 4runners with the 31" tire option. Here's more info on how to find the gear codes: http://www.brian894x4.com/Gearratiosanddiffs.html
Old Aug 13, 2011 | 04:49 PM
BamZipPow's Avatar
I ran both of these part numbers through ToyoDIY.com and it only cross-referenced to the T-100. No cross reference to the 3rd gen Camry...
43430‑34010 (w/o ABS)/43430‑34020 (w/ABS) was replaced by 43430-34011 (w/o ABS)/43430-34021 (w/ABS)
Using ToyoDIY.com...these are the part numbers fer the drive shaft on the 3rd gen Camry, Japan made...
43420 SHAFT ASSY, FRONT DRIVE, LH
43420‑06010 GKN 1 $874.81
43420‑06020 W(ANTI-LOCK BRAKING SYSTEM), GKN (06/1991 - 08/1993) 1 $874.81
43420‑06050 GKN (09/1993 - 07/1994) 1 $839.04
43420‑06060 W(ANTI-LOCK BRAKING SYSTEM), GKN (09/1993 - 07/1994) 1 $839.04
43420‑33010 TOYOTA 1 $736.08
43420‑33020 W(ANTI-LOCK BRAKING SYSTEM), TOYOTA 1 $736.08
43410 SHAFT ASSY, FRONT DRIVE, RH
43410‑06010 GKN 1 $946.37
43410‑06020 W(ANTI-LOCK BRAKING SYSTEM), GKN (06/1991 - 08/1993) 1 $946.37
43410‑06050 GKN (09/1993 - 07/1994) 1 $904.09
43410‑06060 W(ANTI-LOCK BRAKING SYSTEM), GKN (09/1993 - 07/1994) 1 $904.09
43410‑33010 TOYOTA 1 $792.25
43410‑33020 W(ANTI-LOCK BRAKING SYSTEM), TOYOTA 1 $792.25
Part number fer the USA made Camry...
43410‑06010 1 $946.37
43410‑06020 W(ANTI-LOCK BRAKING SYSTEM) (09/1991 - 08/1993) 1 $946.37
43410‑06050 (03/1993 - 07/1994) 1 $904.09
43410‑06060 W(ANTI-LOCK BRAKING SYSTEM) (09/1993 - 10/1993) 1 $904.09
43420‑06010 1 $874.81
43420‑06020 W(ANTI-LOCK BRAKING SYSTEM) (09/1991 - 08/1993) 1 $874.81
43420‑06050 (03/1993 - 07/1994) 1 $839.04
43420‑06060 W(ANTI-LOCK BRAKING SYSTEM) (09/1993 - 10/1993) 1 $839.04
Old Aug 13, 2011 | 07:03 PM
the numbers I got were from toyotapartszone.
Old Aug 14, 2011 | 09:32 AM
BamZipPow's Avatar
Unhappy
I also cross-referenced the part numbers through Concelli Parts Center, 1st Toyota Parts, Toyota Part Sales, and Toyota Parts Outlet. No cross over to the Camry CV shafts.
Old Aug 14, 2011 | 09:36 AM
BamZipPow's Avatar
Doing a quick look up on RockAuto.com...the CV shafts don't even look like they will bolt up to the IFS differential of the T-100.
http://www.rockauto.com/catalog/rafr...&parttype=2288
Old Aug 14, 2011 | 10:06 AM
yeah just checked toyotapartseast which seems to use the same parts software as toyotapartszone and same thing numbers don't match either, this is odd, almost feel bad sending that info out.
Old Aug 20, 2011 | 08:49 PM
trythis's Avatar
My old 89 toyota pickup 4x4 automatic 22re had 4.56 3rds.
Old Aug 20, 2011 | 09:31 PM
streetlancer's Avatar
^hah, i like your sig. Nice turtle!
