93-98 T100s All T100 trucks
Wheel Stud Replacement
Old Nov 16, 2010 | 07:59 PM
8lugnuts's Avatar
Does anyone know the factory size/style of wheel studs for our T's? I need to replace the studs on the right front because three of them are stripped to the point where I am afraid to take the wheel off, might not get it back on.
Do you know where I can get new wheels studs? Are they only available through the parts dept. of the local yota dealer?
8lugnuts
Old Nov 16, 2010 | 10:45 PM
DirtyOregonKid's Avatar
HEHE, I have 5 studs on my runner that are sheared. I figure I'll just get them replaced with my next tire rotation
Old Nov 19, 2010 | 09:13 AM
Kookadala's Avatar
The front wheel studs are a pain to replace as you have to remove the front hub, which requires a special socket which is over 2-inches in diameter. The studs themselves are metric as I recall, like everything else on Toyota. You should be able to get them at any auto parts store, just be sure to buy a few extra to keep in the glove box, as they are not very expensive. The hub socket was the expensive part, at 30 bucks or so, just don't buy it at the dealer.
Old Nov 21, 2010 | 09:05 PM
8lugnuts's Avatar
I'm having my local shop do the work since they have the lift and all the air tools. I just need to purchase the studs to bring to them. I really need to know the dimensions and style of metric stud(thread) for my T. I want them to match all the others.
Old Nov 22, 2010 | 10:17 AM
4Crawler's Avatar
For 3 studs, probably your best source is the local Toyota parts VIN number of you truck in and they can look up the correct part for you.
Old Nov 22, 2010 | 10:27 AM
Kookadala's Avatar
found this in another post - 12mm 1.5 pitch
Old Nov 22, 2010 | 10:40 AM
SigEp4Runner's Avatar
They are 12mm-1.5 as stated above, just did my front driver side last night. I picked my wheel stud up at Napa.
Old Nov 24, 2010 | 05:12 AM
8lugnuts's Avatar
I am going to do all six, might as well since the hub/wheel assembly will be off and it won't cost any more in labor to do all six.
Old Nov 24, 2010 | 05:13 AM
8lugnuts's Avatar
I appreciate the responses guys, I am heading to NAPA this morning to order the parts.
Old Nov 26, 2010 | 05:22 PM
8lugnuts's Avatar
Lug nuts
FWIW: Stopped into the local Carquest today instead of Napa since I was closer to it. The studs listed for my truck were in stock and I got all six. On the stud face there is a 266 in an arc shape stamped at the top, a W in the middle, and 10.9 in a reverse arc at the bottom. Just to make sure, I took one out to my truck, spun one of the stock factory acorn nuts off one stud and was able to screw it on to the new one with some effort but it went on perfectly until it bottomed out. Have no idea what the numbers mean and how they relate to the responses above, maybe someone can explain it.
Old Nov 27, 2010 | 08:46 PM
8lugnuts's Avatar
Worst nightmare realized!
it figures: I went to rotate my wheels front-2-back like I stated I wasn't going to and when I got to the third lugnut to spin it off it just spun like a loose marble in the socket on my impact wrench....the stud it loose in the hub! I'm guessing the gorillas who put my tires on earlier this year reamed that nut onto the stud w/o hand-screwing it on 1st and just busted it out of the hole, or worse, stripped the splines in the hub!
Now I'm screwed, especially if I get a flat. Anyone have any ideas how I can get this nut off w/o destroying the wheel or hub?
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
