96 2wd rear bushings
Maybe the Tacoma bushings might work.
Give Energy Suspensions a try...
http://www.energysuspensionparts.com...?prod=8%2E2108
This should be fer both upper and lower.
Stock number fer the lower rear bushings is 90385‑18016. This also crosses over to the 1995.5-2004 Tacoma...
Stock number fer the upper rear bushings is 90385‑18017. This also crosses over to the 1995.5-2004 Tacoma...
http://www.toyodiy.com/parts/xref?v=...2&s=9038518017
Part 90385‑18017 (BUSH(FOR REAR SPRING SHACKLE UPPER)) was found on the following models:
Date range Model Frames/Options Found in diagram
01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 48-04: REAR SPRING & SHOCK ABSORBER
Model Dates: Matching Models: Model Options: Links to diagrams:
01/1995-05/1997 RZN161L-TRMDKAB DLX, NAP, USA, RCB, T1, 3RZFE, EFI, MTM, 5F, CBU, W 48-04
09/2000-08/2004 RZN161L-TRPDKAB DLX, NAP, USA, RCB, T1, 3RZFE, EFI, ATM, 4FC, CBU 48-04
09/2000-08/2004 RZN171L-CRMDKAB DLX, NAP, USA, XTR, T1, 3RZFE, EFI, MTM, 5F, CBU, W 48-04
09/2000-08/2004 RZN171L-CRPDKAB DLX, NAP, USA, XTR, T1, 3RZFE, EFI, ATM, 4FC, CBU 48-04
01/1995-05/1997 VZN160L-TRMDKAB DLX, NAP, USA, RCB, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04
09/2000-08/2004 VZN170L-CRMDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04
06/1997-08/2000 VZN170L-CRMGKAB SR5, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04
09/2000-08/2004 VZN170L-CRPDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4FC, CBU 48-04
06/1997-08/2000 VZN170L-CRPGKAB SR5, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4FC, CBU 48-04
01/1995-08/2004 TOYOTA TACOMA RZN140,150,19*,VZN150,195 48-04: REAR SPRING & SHOCK ABSORBER
01/1995-05/1997 RZN140L-TRMDKAB DLX, NAP, USA, RCB, T1, 2RZFE, EFI, MTM, 5F, CBU, W 48-04
06/1997-08/2000 RZN140L-TRSDKAB DLX, NAP, USA, RCB, T1, 2RZFE, EFI, ATM, 4HC, CBU 48-04
09/2000-08/2004 RZN150L-CRMDKAB DLX, NAP, USA, XTR, T1, 2RZFE, EFI, MTM, 5F, CBU, W 48-04
06/1997-08/2000 RZN150L-CRSDKAB DLX, NAP, USA, XTR, T1, 2RZFE, EFI, ATM, 4HC, CBU 48-04
09/2000-08/2004 VZN150L-CRMDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04
06/1997-08/2000 VZN150L-CRSDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4HC, CBU 48-04
08/1992-06/1998 TOYOTA T100 RCK10,VCK1*,2* 48-04: REAR SPRING & SHOCK ABSORBER
Yotadawgjr
10
Aug 23, 2015 10:51 AM
1996, 2wd, absorber, bushing, energy, forum, parts, replacement, shock, suspension, t100, tacoma, wwwtoyodiy, xref
