96 2wd rear bushings
Does anyone know of other than the dealer which bushing kit will work with for the rear of my 96 t100 2wd?
Maybe the Tacoma bushings might work.
Give Energy Suspensions a try... ;) http://www.energysuspensionparts.com...?prod=8%2E2108 This should be fer both upper and lower. ;) Stock number fer the lower rear bushings is 90385‑18016. This also crosses over to the 1995.5-2004 Tacoma... :D Stock number fer the upper rear bushings is 90385‑18017. This also crosses over to the 1995.5-2004 Tacoma... :D http://www.toyodiy.com/parts/xref?v=...2&s=9038518017 Part 90385‑18017 (BUSH(FOR REAR SPRING SHACKLE UPPER)) was found on the following models: Date range Model Frames/Options Found in diagram 01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 48-04: REAR SPRING & SHOCK ABSORBER Model Dates: Matching Models: Model Options: Links to diagrams: 01/1995-05/1997 RZN161L-TRMDKAB DLX, NAP, USA, RCB, T1, 3RZFE, EFI, MTM, 5F, CBU, W 48-04 09/2000-08/2004 RZN161L-TRPDKAB DLX, NAP, USA, RCB, T1, 3RZFE, EFI, ATM, 4FC, CBU 48-04 09/2000-08/2004 RZN171L-CRMDKAB DLX, NAP, USA, XTR, T1, 3RZFE, EFI, MTM, 5F, CBU, W 48-04 09/2000-08/2004 RZN171L-CRPDKAB DLX, NAP, USA, XTR, T1, 3RZFE, EFI, ATM, 4FC, CBU 48-04 01/1995-05/1997 VZN160L-TRMDKAB DLX, NAP, USA, RCB, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04 09/2000-08/2004 VZN170L-CRMDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04 06/1997-08/2000 VZN170L-CRMGKAB SR5, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04 09/2000-08/2004 VZN170L-CRPDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4FC, CBU 48-04 06/1997-08/2000 VZN170L-CRPGKAB SR5, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4FC, CBU 48-04 01/1995-08/2004 TOYOTA TACOMA RZN140,150,19*,VZN150,195 48-04: REAR SPRING & SHOCK ABSORBER Model Dates: Matching Models: Model Options: Links to diagrams: 01/1995-05/1997 RZN140L-TRMDKAB DLX, NAP, USA, RCB, T1, 2RZFE, EFI, MTM, 5F, CBU, W 48-04 06/1997-08/2000 RZN140L-TRSDKAB DLX, NAP, USA, RCB, T1, 2RZFE, EFI, ATM, 4HC, CBU 48-04 09/2000-08/2004 RZN150L-CRMDKAB DLX, NAP, USA, XTR, T1, 2RZFE, EFI, MTM, 5F, CBU, W 48-04 06/1997-08/2000 RZN150L-CRSDKAB DLX, NAP, USA, XTR, T1, 2RZFE, EFI, ATM, 4HC, CBU 48-04 09/2000-08/2004 VZN150L-CRMDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 48-04 06/1997-08/2000 VZN150L-CRSDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4HC, CBU 48-04 08/1992-06/1998 TOYOTA T100 RCK10,VCK1*,2* 48-04: REAR SPRING & SHOCK ABSORBER |
