PDA
View Full Version : Tires & Wheels
Pages : 1 [2] 3 4 5 6 7 8 9 10
  1. Will these fit?
  2. 37's on factory alloys
  3. Will my 33x12.5 tires fit on axle flipped SFA 85' pickup?
  4. HELP!!!! center cap problems in New York
  5. Flipping used tires to white in?
  6. Marty Mcfly wheels
  7. Can't decide on a tire
  8. What wheel offset to get?
  9. Need Suggestions For Tires
  10. Who's running SA hubs?
  11. No bfg ko2 in 15" sizes!!!!!
  12. Falken Wild Peak A/t
  13. Does anyone have info on these
  14. new member here with rim ?
  15. Anybody running these wheels on their Yota??
  16. Help me choose which new wheels to buy!
  17. Early 90's sr5 alloy lugs?!
  18. Any other center caps fit these wheels?
  19. Anyone know this wheel?
  20. 37"BFG Hummer 37x12.50x16.5 tires on Procomp 16.5x8.25?
  21. Name of these wheels?
  22. Old SR5 X-Wheel Center Cap Surprise
  23. Which stock 15" wheels will fit my 99 4Runner?
  24. What are these wheels off of?
  25. 31 inch tire option on 93 4runner???
  26. What kind of wheels are these?
  27. 33x9.50 Swamper TSL SX
  28. Irok ND vs kenda klever mt
  29. 10" wheels
  30. How many miles did your last mudd tires last
  31. Wheel Spacers for 85 pickup 4x4
  32. Fj steelies
  33. 31x10.50 15s on a 6 or 7 or 8inch rim?
  34. Which Tires To Get? 95 4runner
  35. 30/9.5 R15 Tires
  36. Where to Find These Wheels?
  37. 315 75r16 Rubbing
  38. 33/10.50/15
  39. Revo 2 in 285/75 info - searched, not finding much
  40. Is 4.30 a decent gear ratio with v6 to pull 38's
  41. Wheels That FIT Thread - Post your wheel specs here
  42. Wheel specs for 85 4runner w/V6 caliper upgrade??
  43. Are there ANY 15" wheels that fit a 3rd gen 4runner at all?
  44. 83 pickup tires/suspension required?
  45. Wheel size for offset...backspacing??
  46. Backspacing
  47. Best tires to get
  48. Clean brake dust from 3rd gen 4Runner rims?
  49. Anyone running 17x9 rims
  50. 16" wheels vs 15" wheels
  51. Mickey Thompson Baja Lock vs Ion Alloy 174?
  52. Thoughts regarding these 80-series rims (photos)
  53. '85 4Runner Wheel Fitment
  54. What rim is this
  55. 37" tires
  56. Wheels, hub centric or not, and spacer questions.
  57. 2006 Toyota 4Runner SR5 V8, BIGGER TIRES DESIRED
  58. good offroad tires for stock 97 4runner
  59. IROKS OR LTB's
  60. super swamper LTB from tirepackage.com
  61. swamper ltbs from tire package
  62. Wheel - Chou Seiki - acorn vs shank lugs
  63. 1979-83 analog radio help
  64. 1999 4runner lug nuts
  65. Stretched 33s?
  66. Balancing 37s..
  67. 1990 Toyota Pickup. Went to 16" wheels
  68. Lug Nuts....Spline vs acorn
  69. 33/15.50/15 baja claws
  70. Moto Metal rims good quality?
  71. Are these wheels OEM stock?
  72. Summit or Pro Comp
  73. 1985 Toyota 4runner independent front end rims
  74. do you know?
  75. looking to buy american outlaw II's
  76. Anyone running retreaded tires?
  77. 33x10.50r15 on stock toyota pickup
  78. will these fit? 1984 4x4 tota
  79. 33-12.50-15
  80. 89 4runner wheel help
  81. 14.50 wide tire on a 8 wide rim?
  82. Recomendations for '87 2wd replacement tires
  83. Blackrock 942 15x8 fit 88 pickup?
  84. Switch tires?
  85. 30x9.50x15 0n 17in wide wheel
  86. what do you guys think?
  87. Replace 1990 2wd PU Wheels/Rims, what fits?
  88. Pizza cutters!
  89. What backspacing is needed for 1st pickups?
  90. 86-89 33x10.5 pics
  91. What Causes this type of tire wear? (pics inside)
  92. 33" TOYO OC M/Ts
  93. What size tires?
  94. Refinishing 1/2nd gen 4Runner SR5 rims?
  95. Where to find deeper offset for 5 lug rims?
  96. 255 85 16 on stock-ish 94 4runner
  97. Lug Nuts for Alloy Wheels
  98. Tire Question
  99. Why so few Load C and D range tires??
  100. Got new Toyo MTs
  101. 79 truck wheels
  102. Wheel size
  103. 99 4runner new rims and tires
  104. Going to small tires...thoughts?
  105. full size spare tire rim, should it be the same as the other wheels for 2007 RAV4
  106. Cooper tires Discoverer STT?
  107. Pics of "Factory" Enkei Wheels on Pickup (2nd/3rd gen)
  108. T-100 wheels on a 90 4wd?
  109. 1990 PU bolt pattern/rims question
  110. Cupped/Scalloped Tires. Should I replace?
  111. IROK ND's?
  112. Increase in tire cost?
  113. Wrangler A/T Adventure w/Kevlar?
  114. New member - tire/wheel size question
  115. Alcoa Wheels
  116. Question About Wheel Backspacing...
  117. Used tire tread question
  118. Looking for specific "Daytona" wheels!
  119. Wheel Tire Combo Switch for 2013 LTD 4Runner?
  120. Wheel swap
  121. Replacing Hub/Bearing Assembly
  122. New Dick Cepek Tires!
  123. 35s on 7" wheel?
  124. Good paint for rims
  125. I have a flat and the only spare I have is a 32
  126. 4 cyl max tire size?
  127. Siping KM2's?
  128. BFG KM2's with snow?
  129. Aluminum hubcentric rings
  130. Need traction!
  131. Looking for a Little 411 Tire Help, Post Pics Please
  132. Nexen Roadian M/T
  133. 31x10.50-15 MT on stock truck
  134. Identify these tires?
  135. AT Tire Confusion 3rd Gen 17" Tundra Rims
  136. 4.88's or 5.29's
  137. New Rims
  138. 03-09 5 spoke rim on 3rd gen 4Runner help
  139. Failed BFG KO
  140. Nissan center cap on Toyota Steelies?
  141. Kmc Enduro
  142. Toyota Steelies weight 16'' #4260135740
  143. grooving tires
  144. 35s on 4" lifted 91ex cab sr5
  145. Tire selection
  146. Center cap removal
  147. Ultra 164 on 3rd gen 4runner
  148. 33x12.50 baja claws on 92 4runner?
  149. Anyone use Trazano cr857 tires?
  150. How large of tires can you fit on a 1st gen with no lift?
  151. how big of a tire for a 4cyl 2wd taco
  152. New GY Authority Tires
  153. 2004 taco xcab 2wd 4cyl
  154. Anybody paint over the red stripe on their black steelies?
  155. 2004 2WD tacoma xtcab
  156. Will Mickey Thompson Classic II's fit?
  157. what size tires for stock 2001 4runner sport
  158. 2" Lift on a 1994 4wd. Will 33" 12.50 fit?
  159. Fj cruiser wheels
  160. Quick Help
  161. How many miles am I actually traveling?
  162. Running different tires sizes?
  163. newbie here!
  164. 17s-18s on a 91 4x4.
  165. Tire fitment
  166. 16x8 pacer worrior rims with spacer plates
  167. What tires will fit best?!
  168. Help!!! Unknown wheels?!?
  169. Hot knifing Super Swampers
  170. tire and gear calculator
  171. Help identify these wheels
  172. new tires and rims
  173. aluminum rim corrosion help
  174. moderately priced tires for hwy/4x4
  175. Common Wheels/Tires for Stock Truck
  176. Rim backspace and caliper clearence?
  177. 127mm to inches...Help
  178. steelies on my truck
  179. Post tire and fender pics
  180. questions about tsls
  181. New steel wheels bent?
  182. Method Racing
  183. 16" or 17" Rims On A 2002 4Runner??
  184. Lug nut question
  185. Will these rims fit on my sequoia?
  186. 1st gen wheels on 2nd gen 4-runner
  187. Trying to find out if these would fit my 1985 truck
  188. Wheel Identification??
  189. Help photoshop my beadlock rings
  190. Whats with 33 9.50 15 BFG AT KO availability?
  191. Lookin for info on wheels
  192. Dueler A/T Revo 2 1998 2wd 4Runner question
  193. Coupon for tires at these stores, totally legit!
  194. Raceline Rockcrushers
  195. Tire and rim score
  196. Will it fit or rub????
  197. These wheels on my Yota?
  198. Rims that fit Yota trucks?
  199. sidewall crack near bead.
  200. Bent rim or bent axle?
  201. General AT2 Grabbers (Advice)
  202. Tire Size... PLEASE HELP!!! 265/75/16
  203. Mismatched Spare Tire
  204. Another SFA/IFS wheel question (not about spacers)
  205. Wheel specs?
  206. 1s gen tire and wheel help
  207. 3rd Gen T4r Desert Dune with Pro Comp 16x8's flat black, anybody have pics?
  208. Would this look way to goofy?
  209. Backspacing on 1992 4runner Q's
  210. Very helpful Tire and Rim Size Calculator
  211. Pitbull Rockers
  212. 285/75R16s on stock wheels?
  213. Nitto terra grappler 265/70R17 P or LT?
  214. Advice on Rim and Wheel Package
  215. New Toy / Tire Help : 205/R16??
  216. Review: Falken Rocky Mountain MTS
  217. buying new wheels -question about offset
  218. Needing some advice on BFG All-Terrrain or Mud Terrain
  219. Need Advice in Choosing tires for an '09 tacoma
  220. center caps on steel wheels
  221. what factory alloy wheels will fit 85 4wd
  222. Opinions on Fuel wheels for general offroad purposes....
  223. Techno tire with Green Diamond granules
  224. What setup do you have on these Steels ?
  225. Rotation Problem? Help!
  226. score!
  227. BFG AT KO 265/75/16 E on a 98 4runner too much???
  228. Stretched tires question!!
  229. TRXUS MT Balance Issue after 6K miles
  230. toyo mt knock off?
  231. ten inch wheels???
  232. Mismatched front tires
  233. restoring late 90's Tacoma wheels
  234. 15x8 wheel back spacing with 33" tire
  235. So what's the deal with the TX Pros?
  236. 15 inch wheels to 16s, same size tires
  237. falken rocky mountain ats
  238. general grabber AT2 vs GY authority
  239. early 90s steel rims 15x7
  240. Good deal on rims at 4wheelparts.com
  241. Do you think my 3rd gen 4runner will fit 305/70/16?
  242. Tire sizes Toytota noob
  243. 33x10.5 or 33x12.5?
  244. Red letters VS. White....
  245. Cheap a/t tire
  246. jerk trashed my truck
  247. 97-00 15x7s on a 03 Tacoma?
  248. 91 Truck one rear wheel locked up...
  249. What tires are these?
  250. 30x9.5 15s on 15x6s?
