33x10.5 or 33x12.5?
Old Jul 23, 2012 | 07:59 PM
manuk's Avatar
33x10.5 or 33x12.5?
82 Toyota SR5. I'm trying to decide between 33x10.5 or 33x12.5. I've gotta 2" lift on it so I don't want it to look like I've got pizza cutters but I don't want to go too wide and have them rub when I turn the wheel. Also, do you think it'll make that big of a difference in my gas mileage? I'm running 31's now so I'm wondering how big of a hit my gas mileage is going to take.
Thanks.
Old Jul 23, 2012 | 08:08 PM
StewsRunner's Avatar
32x11.5?
Old Jul 24, 2012 | 09:54 AM
possum34's Avatar
Id go with the 10.50s. They would pull better and rub less then 12.50s. On the MPG you proble will lose 2 MPG or so.
Old Jul 24, 2012 | 09:23 PM
manuk's Avatar
You think there would be much difference between 33x 10.5 and 32x 11.5?
Old Jul 25, 2012 | 07:43 AM
4Crawler's Avatar
One benefit of the 10.50s is they can be used on the stock 6" wide wheels, the 12.50s probably will require new wheels.
- http://www.4crawler.com/4x4/BFG_AT_KO.shtml
Old Jul 25, 2012 | 12:02 PM
liveoffroad's Avatar
i'm a big fan of 33x10.50's. that seems to be an ideal width for the weight of these vehicles. 12.50's float a little too much on loose gravel or snow, decreasing traction. also i think you would see a slight difference in gas mileage.
Old Jul 26, 2012 | 08:28 AM
highonpottery's Avatar
OTOH if you go with 12.5's you will have significantly more choices for tires, and if you need a tire in an emergency a shop will most likely have a 12.5 on the shelf vs. the 10.5 which not many manufacturers produce, and most people swoop up quick since they fit most vehicles w/o mods.
coffey50
Jul 28, 2015 10:55 AM
bobbybouche
Jun 18, 2015 10:22 AM
sadiq
Aug 24, 2008 05:23 AM
safado4
Mar 14, 2006 07:39 PM
shiftless89
19
Mar 31, 2005 11:53 AM
