what size tires for stock 2001 4runner sport
Old Mar 25, 2013 | 01:07 PM
b_stone81's Avatar
So I have a 2001 4runner sr5 sport. Its literally the exact same thing as the limited just with the hood scoop. I don't have a lift its all stock with no sagging. What would be the best off road/ all terrain tire, and size should I put on it? It has p265 75 r16 tires on it now which is 31 inches tall. I want bigger or wider if possible.
Old Mar 25, 2013 | 01:44 PM
habanero's Avatar
That's....about it. You should be getting frame rub at full lock as it is. Upper a-arms are the next thing you'll bump. For grins we attempted to stick a 285/75/16 on the 99 (taller than your 01), no fitty. If you're not going up or out you're prolly about as good as you want. As for best tire, what are you planning to do with it terrain wise?
Old Mar 25, 2013 | 01:50 PM
b_stone81's Avatar
Its the stock tire size. It doesn't scrub but its close. Me and my buddies trail ride a good bit and my tires aren't good for that. I don't need anything serious like M/T but a good all terrain or something between an allterrain or mud terrain. Hoping for something affordable but if not oh welk .
Old Mar 25, 2013 | 01:52 PM
habanero's Avatar
Not P265/70r16? I've got 265/75r16 on the 99, but they aren't stock size, at least for the 96-99 4Runners.
Old Mar 25, 2013 | 02:02 PM
b_stone81's Avatar
You know what I think they are the 265 70 r16. Its a 31 inch talk tire I do know that
Old Mar 25, 2013 | 02:11 PM
habanero's Avatar
Yes then, 265/70r16. You did say 31's but I chose to pay attention to the actual size. 265/75r16 are close to 32". That's your tire with an extra 1/2" all around the outside, width being the same.
Trails...mud, clay, dirt, rock...? What do you have now? What do you wish they'd do better?
Old Mar 25, 2013 | 02:20 PM
BeMiceElf's Avatar
I run 235/85 BFG's on my 4runner. Love them.
They are also alot cheaper than other options.
Old Mar 25, 2013 | 02:39 PM
b_stone81's Avatar
How tall are they?
Old Mar 25, 2013 | 03:28 PM
BeMiceElf's Avatar
Right at 32"
Old Mar 25, 2013 | 03:37 PM
b_stone81's Avatar
And they fit good? What's the difference in that and a LT265 70 r16
Old Mar 25, 2013 | 03:54 PM
BeMiceElf's Avatar
265/70 is about a 31x10.5.
235/85 is about a 32x9.5
Narrower tires tend to fit better with less clearance issues and with less rotating mass to help with mileage.
Old Mar 25, 2013 | 03:58 PM
b_stone81's Avatar
Okay. You know anything about Goodyear wrangler duratracs?
Old Mar 25, 2013 | 06:08 PM
BeMiceElf's Avatar
Nope. I've only bought BFG or super swamper. Sorry.
Old Mar 31, 2013 | 07:28 PM
brorealz's Avatar
For a decent lasting tire that performs well for a casual/weekend warrior, Michelin ltx a/t 2
Old Mar 31, 2013 | 07:42 PM
b_stone81's Avatar
Well I was down a trail today that had some surface mud. No ruts or anything and I went to turn around on a hill and I kept loosing traction but I finally worked my way up. So I want something that will get me out of those situations but also good on trails and in dirt and stuff. Rough country just came out with a bang in 3" suspension lift that will allow 285 75 r16 so rough country says which is a 33.1" tall tire and 11.3 wide. Solo Idk
Old Mar 31, 2013 | 07:49 PM
brorealz's Avatar
For a quality ride I try to stay away from "rough" country
Old Mar 31, 2013 | 07:55 PM
b_stone81's Avatar
I mean I kinda like rough country. One of my friends has a 4" on a jeep xj and another has a 6" on a Chevy 1500 and its not to bad for the price you pay. And the lift for my 4runnee is only 260 dollars. I'm not to hard to please with it but eventually when I get another truck ill go all out with the OME stuff. What would you recommend though?
Old Mar 31, 2013 | 08:16 PM
brorealz's Avatar
Rough country isn't bad for an affordable lift and it gets the job done. I like OME, and some of the pro comp lifts
Old Mar 31, 2013 | 08:24 PM
b_stone81's Avatar
What's the tallest pro comp goes with a 4runner?
Old Mar 31, 2013 | 09:13 PM
brorealz's Avatar
They make a 4 inch suspension, im sure they have body lifts as well
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Whatever123
Sep 30, 2015 12:12 AM
