Does anyone have info on these
I need backspacing info on these wheels. they are from a 2010-2013 4runner and i cannot figure out if they will work for my 02 tundra
http://www.ebay.com/itm/New-20-x-8-Toyota-4Runner-Limited-Style-Alloy-Wheel-Rim-2003-2013-Set-4-PCS/231359349980?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D0050bbae3d914b629af19a1616eaf901%26pid%3D100033%26rk%3D1%26rkt%3D4%26sd%3D231359349980
it says offset 30 but im not sure if its +/-
since the spokes on that wheel are essentially flush with the face, my gut says they are positive offset....meaning the wheel's mounting surface is further outward than the wheel's center line.
IIRC, tundra went back to the 5-lug wheel because it's stronger than the 6-lug. you can also use wheel spacers if you're set on a particular wheel and need to make it work.
TheBFA
Feb 15, 2020 06:55 AM
buckz6319
Aug 5, 2017 03:50 AM
dirk89
Oct 1, 2015 05:15 PM
