What size tires?
Old Nov 3, 2013 | 12:04 PM
dementedfish's Avatar
What size tires?
I have a 97 4Runner 4x4 and I have two sets of rims, stock 16x7 4Runner Rims and 18x8 Land Cruiser rims. I'm looking at buying a new set of all season tires and winter tires but can't decide what size to buy. I was recommended 265/70 R16 tires on the 16x8 Land Cruiser rims (BFG A/T KO's) and 265/75 R16 tires (Goodyear SilentArmors) for my winter set on my 16x7 rims. I wanted to see what all of your opinions were and if anyone has experience running Land Cruiser rims on their stock suspension. Thanks!
Old Nov 4, 2013 | 10:04 AM
YoungFeller's Avatar
Sure, you can run Land Cruiser wheels on your 3rd-gen 4runner just fine. I assume the LC wheels are 16x8 and not 18x8 like you first typed.
265/70R16 and 265/75R16 are common sizes on the 3rd gen. The size difference between them is pretty minimal.
For the winter set, you might consider the 235/85R16 size. It is about the same diameter as the 265/75R16 but is a good bit narrower to better cut through slush and put down good ground pressure on the snow pack for better grip. Given the same tread pattern and rubber compound, a narrower tire usually has better winter performance than a wider one. Skinny tires also do well on the highway and on the trail--you can run them all year.
AT tires like the SilentArmor and BFG all-terrain are perfectly good for running year-round. Why not simplify and pare down to just one set of rolling stock instead of two? Two sets can be a pain, with the storage, switching, and cost and complexity of keeping two sets of tires balanced and fresh instead of just one. I gave up keeping two sets a long time ago and haven't looked back.
Old Nov 4, 2013 | 01:20 PM
Yes I did mean 16x8. Thanks a lot for the help. My research I've done shows that the KOs are much better all season, and the silent armors are much better for snow so I think I'm going to go that route.
Old Nov 5, 2013 | 12:01 PM
From what I've seen, the snow performance of the Silent Armors and BFG ATs are pretty similar...not different enough to buy two sets.
Here's the survey results table on Tirerack:
http://www.tirerack.com/tires/survey....jsp?type=ORAT
The BFG ATs have an 8.6 rating in light snow, 8.3 in deep snow and 7.2 in ice.
The Silent Armors have a 8.8 in light snow, 8.6 in deep snow and 7.8 in ice.
I think it'd be very difficult to justify buying two sets for such similar performance. Both tires are branded with the snowflake symbol, allowing for use without chains in many chain-restricted areas.
If you are set on a different set of winter tires, I would select an actual winter tire.
Old Nov 5, 2013 | 01:32 PM
SCToy's Avatar
I'd take a look at the Goodyear duratrac
Old Mar 14, 2015 | 07:58 PM
NorCalMaiTai's Avatar
94 land cruiser tire size
I have a 94 land cruiser I just picked up, all stock. anyone recommend a tire size for that year? Im thinking of going to a bigger tire
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Yotoder865
Jul 9, 2015 07:51 PM
