PDA
View Full Version : Maintenance & Repair Archives
Pages : 1 2 3 4 5 [6] 7 8
  1. Another finally...question about Z2 vs Z5 ?
  2. Alternator Question?? Please Help...
  3. Won't go into gear
  4. Front wheel outer dust seal
  5. Question about AMSOIL
  6. Interior Scuffs?
  7. DIY oil change- YOU NEED THIS MACHINE!
  8. welding
  9. 2nd Gen Fluid Capacities (Already Searched)
  10. Problem with 1993 4-Runner (won't start)
  11. how do i remove stripes
  12. Just making sure (oil)
  13. 3VZE sparkplugs
  14. Good mechanic in E. Phoenix/Scottsdale?
  15. tranny pump inlet flush machine - make your own?
  16. Help!!-Want to change to syn. oil
  17. Stereo Removal for any car (almost)
  18. changing plugs
  19. tranny fluid flush
  20. Found cheaper alternative to PC polisher a.k.a. Corey Cable
  21. When are you supposed to change your timing belt?
  22. Which shop would you trust?
  23. PVC valve
  24. 4wd not being used for a while
  25. clutch pedal falls away, doesn't disengage
  26. 120,000 ml. service
  27. Spark plug question
  28. 94 4x4 doesnt start the same
  29. Rear Axel Seal Problems
  30. Cleaning 4th gen tip
  31. 30k service questions
  32. Re-starting Toyota after 1 year
  33. valve adjustment 3.4v6?
  34. Door lock
  35. Which Oil to use in '96 4Runner?
  36. Tranny problems 2nd and reverse
  37. 2nd gen won't start.
  38. transfer case fluid
  39. adjusting parking brake at the drum
  40. High pitched squealing
  41. Question about direct ignition and spark plugs
  42. drum brake squeaking
  43. easy, easy and easy- brake job
  44. Transfer Case Question
  45. Oil and Filter change
  46. Brake anti squeek "stuff"
  47. toyota oil filter # 90915-YZZB1
  48. atf recommendations please
  49. 2nd gen Auto Trans fluid change?
  50. n00b oil change question
  51. Changed oil on 03 4Runner, a nightmare
  52. brake job
  53. Only 50psi in cylinder #6 in my 2nd Gen...
  54. 2nd Gen 4Runner 3-VZE PCV valve nightmare
  55. cigarette lighter
  56. Where's my oil going?
  57. Leather Seats/Care
  58. pcv valve ?
  59. Washing the engine, what is the real deal?
  60. Spare 2 1/8" Socket for loan
  61. Rough Rough 3.4L
  62. Seal question..
  63. Aisin rebuild but still no worky
  64. Tire Pressures
  65. Trans temp light keeps coming on...
  66. Mass Air Flow Meter question
  67. Porter cable substitute
  68. 2nd Gen 5-Speed Shifting Troubles
  69. Carb cleaner vs throttle body cleaner---same thing?
  70. brake pad replacement
  71. why can't I use keyless entry with vehicle on?
  72. where to by Yota' parts
  73. Need fuel filter R&R advice for my 96
  74. synthetic or fossil oil in new 4Runner
  75. Timing Chain Question
  76. Check Engine light!
  77. Replacing my rotors...What else do I need?
  78. Faulty power window switch
  79. 2002 taco lube
  80. removing '89 truck bed
  81. Squealing brakes
  82. Factory Service Manual on CD
  83. O2 sensor
  84. Oil Fanatic Forum
  85. Gas tank
  86. Spark plug and wire change today---but "pulsing"---what's the cause?
  87. clutch install
  88. HALP! Ruined my finish
  89. fuel filter replacement
  90. newbie with oil question
  91. Mobil1 vs Castrol
  92. Gas Line
  93. Aisin hub 10mm bolts
  94. skid plate removal 03 4Runner changing oil
  95. removing skid plates on 03 4Runner for oil
  96. toyota oil filter
  97. Brake Pads on Sequoia
  98. Power Windows
  99. Where to buy Hammerite paint?
  100. Need manual hub help
  101. Cooler Radiator
  102. Disappearing OIL, No Leak, Use Heavier Oil?
  103. the magical dissapering oil
  104. missfiring...?
  105. Anyone know anything about this wax/polish?
  106. Maint. of idler pulleys
  107. difference between 2wd and 4wd radiator?
  108. How do you add Transmission Fluid to a Tacoma? Pre-Runner
  109. 2001 Tacoma Dbl Cab 4x4 Trd Power Steering Leak- Again!!!
  110. Mobile vs. Amsoil
  111. Scratches in clear coat
  112. Lean running system
  113. Tie Rod End replacement
  114. How many of you change your own spark plugs?
  115. What rotor are you using??
  116. 60k maintenance...
  117. Heater Core & Dash Tips
  118. Window power
  119. Automatic transmission problems, need help!
  120. Low-Tech Low hassle PS fluid change
  121. fuel filter qestions
  122. Squealing belt---which one is it?
  123. Differental fluid pump?
  124. Missing/Hesitation/Noise
  125. Clay bar - can someone help me out?
  126. Changing brake pads tomorrow night - anything I should know
  127. bad vibes....
  128. 20R, 21R, 22R Engine coolant drain plug question (Long read..main question at bottom)
  129. 22R cold engine valve clearance
  130. Misty lookin' chrome rims
  131. Fan Clutch replacement???
  132. What do you all...
  133. Enjin oil: What brand is the preference?
  134. Missing Cylinder
  135. dealership tire spray
  136. clutch question
  137. gauge lights
  138. rear main seal
  139. Q: wax, paint and belt noise?
  140. Sequoia grease fittings
  141. Switch to synthetic at 110k?
  142. Whats that noise?
  143. Dull tails and reverse light plastic?
  144. Rust Removal and Prevention
  145. Chrome Polish and Stock Wheel Cleaner
  146. Rusty stuff makes me sooooo freekin mad!
  147. your complete tune up?
  148. 22re engine codes
  149. timing chain maintenance
  150. Wiper Blade Replacement
  151. 20w-50 oil
  152. My experience on CV boots
  153. Temp Sensor / engine missing questions
  154. 4Runner Spare Tire
  155. Hot Transmissions???
  156. Best Hand Cleaning Mitt
  157. Meguire's Comes Through Once Again!
  158. Synthetic diff oils?
  159. replacing thermostat with cooler one, will it help?
  160. removing sway bars
  161. coolant in oil, oil in exhaust!!!!! PLEASE HELP! DONT KNOW WHAT IT IS!!
  162. tranny is shifting hard
  163. tail light fuse keeps blowing
  164. fuel filter and torque wrench
  165. Where is the most common place for a 22re head to crack??
  166. headman header install write up
  167. Can I rebuild my calipers??
  168. Valve settings on 3.4 V-6
  169. flushing the transmission
  170. Considering exhaust mod
  171. Simonizing your taco
  172. What to look for when buying used 4Runner?
  173. antenna
  174. My coolant overflow is spewing coolant? any suggestions on what it might be?
  175. stuck bellcrank! !*!*!*
  176. due for tune-up
  177. Seat Covers for 2002 4Runner
  178. 1st Gen Rear window relay
  179. Timing chain and other parts
  180. Pollution device removal
  181. Pictures of spark plug replacement ?
  182. Toyota Oil Filter Internal View
  183. Napa air filters
  184. Good garage in Denver/Lakewood?
  185. 4 hour oil change
  186. Borla Dual Exhaust
  187. What about transfer case??
  188. To all 2001 Tacoma owners
  189. Valvoline 75-90, How much?
  190. Gearing to match tire sizes
  191. Griot's Fine Hand Polish ?
  192. Strange arcing/buzzing from part above fuse box?
  193. prolong oil additive
  194. Air conditioning help
  195. Stupid stupid spark plug hole!!!
  196. 02 tacoma oil filter removal problems
  197. AT filter replacement on flush&fill
  198. Can't get the white lettering clean on your tires?
  199. Drain / Fill plug location on Front Diffs
  200. Grilland Headlights
  201. Rear Springs
  202. oil change
  203. Zaino Brothers - I'm Sold
  204. Does anyone make Leather Seatcovers for the 03 Tacoma's buckets?
  205. Where do you get those manuals?
  206. cleaning leather interior
  207. front cv joints
  208. engine light is on
  209. burning smell after offroad trip
  210. stalling..
  211. opinions from past 22re builders
  212. Holy Cow..$600 for 60K service...?!
  213. speedometer is off on an '01 tacoma
  214. gas gauge is off
  215. Do my valves need to be adjusted?
  216. What causes your brakes to pull to one side?
  217. Limited Slip or Not on 2000 4runner SR5
  218. Quick Question for you Toyota gurus
  219. Who needs their cv halfshaft replaced?
  220. uh oh, lost my bolts to the timing chain cover, anyone know what sizes i will need?
  221. Not to bash, but...
  222. AMSOIL At major retailers
  223. slotted rotors
  224. 20k
  225. P0171.....again.....lol
  226. sorta off topic, but Toyota....
  227. Brake light problem
  228. I almost could have drank it!
  229. how to get radiator support off?? PLEASE HELP ME!!!!
  230. ??Ceramic Brake Pads??
  231. intake noise
  232. Paint Chip
  233. new brake pad install
  234. Timing Belt Change?
  235. Amsoil
  236. Used Turtle Wax's Color Cure this Saturday and...
  237. Rear suspension lean.....
  238. Recall
  239. how often do you guys
  240. Hey I gots some codes
  241. Techies....?
  242. melted fuel injector harness
  243. Got my belts changed today
  244. A Cig Lighter Question...
  245. diff and T case oil change
  246. 22re don't want to's
  247. Idler Arm Maintenance
  248. HOOD PROBLEM as a result of a fender bender
  249. Changing brakes for the first time - question.
  250. 22R Carb install, Any tips?
