1st Gen Rear window relay
Old Jul 13, 2003 | 03:30 PM
cabbage's Avatar
Question 1st Gen Rear window relay
I have a problem with my rear window, the outer key switch would not work, I have to put the key in the ignition to lower the window every time! Think its a bad relay, does anyone know where I can locate it? Thanks!!
Old Jul 14, 2003 | 06:28 AM
mtnfreak's Avatar
Relay is behind the side panel, just behind the driver. You might also want to check the wiring harness between the body and the tailgate (left side). This is a common spot for corrosion.
Old Jul 14, 2003 | 06:40 AM
cabbage's Avatar
Thanks for your help! I will be checking behind the side panel later on today.
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
