Valve settings on 3.4 V-6
Old Jul 18, 2003 | 08:22 AM
I have a '98 4-Runner with the 3.4 V-6 and I have been trying to determine the CORRECT valve settings for this engine. My dealership is being less than helpful. Does anyone out there have this info from a Toyota factory manual?
Old Jul 19, 2003 | 06:50 PM
george16's Avatar
Check underneath your hood. It's written there.
George
Old Jul 19, 2003 | 07:11 PM
Corey's Avatar
Co-Founder/Administrator
If it's anything like the 3.0 engine like I have, you can not adjust the valves like you would a small block Ford or Chevy.
Mine requires shims to do it, and it's hard job at that from some of the tech's I have spoken with at Toyota dealerships.
But then the 3.4 may adjust like the older ones, I am not familiar with the 3.4 at all.
Old Jul 22, 2003 | 07:46 AM
Victor's Avatar
The 3.4 also uses shims. Gadget just responded to that same question in the 4Runners & Trucks section. What can be difficult is that most toyotas have loud injectors that tick. Comparing my truck to other 2nd gens they all sounded the same so I haven't decided to pull a valve cover to check valve clearances.
the1998sr5
15
Jul 14, 2020 08:35 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
coleypull15
Nov 3, 2015 07:41 AM
thefishguy77
Jul 30, 2015 10:59 AM
94whiterunner
Jul 12, 2015 07:15 PM
