Brake anti squeek "stuff"
Old Sep 19, 2003 | 12:46 PM
SHANEMAN's Avatar
question:
i will change my brakes tommorrow. all the threads make mention of using anti squeeking lube on the shims. my toyota book calles for anti seize. will this work as well
Old Sep 20, 2003 | 06:36 AM
amorphous's Avatar
i'm thinking....
i *think* it's the same thing. I'm not 100% - but i'm thinking it is.
Old Sep 22, 2003 | 09:23 AM
Mohamed's Avatar
Anti-seize is NOT the same as anit-squeak. They are two seperate lubes. Ones for prevention of say spark plugs that seize into the plug.
The other goes on the back of the shims so that when the shims move, the plate doesn't rub and cause friction agains the back of the pads and that annoying squeak you hear.
Old Sep 23, 2003 | 08:23 PM
Adam F's Avatar
I just changed my pads and rotors and I did not use the anti squeak stuff. Never heard a thing from my brakes.
Old Sep 23, 2003 | 10:35 PM
Mohamed's Avatar
If you crash you Runner into walls like that, I'd say you never use your brakes to begin with...
Old Sep 24, 2003 | 04:21 AM
delboy's Avatar
It's a copper based grease with very high 'slippy factor'. I believe thats the technical term for it! I got some recently but it was very hard to come by. The guy said no-one buys it anymore.
Old Sep 24, 2003 | 05:51 AM
amorphous's Avatar
intresting stuff....
now, I did coat my shims and pad with the anti-seize quite well....but it wasn't anti-squeal.....and guess what I heard the other day.....a BIT of a squeak! -- now, this is the wierd part....it's only from the right front...and, it's only when I'm JUST BARELY touching the brakes, you know, just to start slowing down....then, it goes away....and if you let off, then touch them down light again...it's gone! strange. Still stops like a bada$$!
keep the rears adjusted,
aaron
Old Sep 25, 2003 | 11:15 AM
Fink's Avatar
What's a good way to fix my brakes after the fact? I have never had any brake work done on my truck since I have owned it (July 14th, 2003), is there anyway to get the squeak to go away without any major disassembly?
Thanks.
Sorry to take over the thread...
Fink
Old Sep 25, 2003 | 11:20 AM
amorphous's Avatar
you could try...
you could try to spray it with brake parts cleaner with the wheel off.....but if that doesn't work, you'll have to pull the pads and re-apply.
~a
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
Jonny246
Jul 12, 2015 04:51 AM
