new brake pad install
Old Jun 3, 2003 | 11:12 AM
data's Avatar
Senior Member
I could have swore Wild_Bill had a write up on replacing brake pads. I can't seem to find it though. Anyone know where I can find it?
Old Jun 3, 2003 | 02:17 PM
rimpainter.com's Avatar
This is what you are looking for my friend.
Old Jun 3, 2003 | 09:16 PM
EDGE's Avatar
Replacing pads on 4Runners is cake, just remove pin the caliper does not even come off
Old Jun 3, 2003 | 09:57 PM
L33T35T 4Runner's Avatar
just dont remove the 4 bolts that actually open the caliper! i did, and this happened
https://www.yotatech.com/forums/show...&threadid=6496
all you gotta do is take out the 2 pins that hold the brake pads in, use a C clamp on each side to press both calipers in, take out old pads, put new pads in, and put the pins back in along with springs and retaining bar thingy
pretty easy once you've done it a first time, of course ,everything is
Old Jun 4, 2003 | 05:45 AM
data's Avatar
Senior Member
what kind of pads did you purchase? i was looking at the toyota pads, but i called autozone and they had some pads for fairly cheap...
Old Jun 4, 2003 | 05:57 AM
pep boys had some raybestos for 19 bucks, so that's what i got
Old Jun 4, 2003 | 07:47 AM
data's Avatar
Senior Member
thanks for the help!
Old Jun 4, 2003 | 10:58 PM
OicnaiC's Avatar
I just changed mine also. Holy Cow! It was so freaking easy. I went with the cheap Autozone ones. They have a lifetime warranty so hey for $15, why not? so far I have no prob with them
Old Jun 5, 2003 | 05:26 AM
They're gonna warp your rotors because it's such a hard material so it can live up to a lifetime warranty.
my brother bought some for his old MR2 and his rotors were warped so badly that they actually had a nice ripling effect you could see from 10 feet away
Old Jun 5, 2003 | 05:44 AM
data's Avatar
Senior Member
yeah i changed mine yesterday also. i was very amazed at how easy it was.
Old Jun 5, 2003 | 06:02 AM
AgRunner06's Avatar
Post
Ok, now how hard is it to replace the rotors on a 4WD?
Old Jun 5, 2003 | 06:40 AM
data's Avatar
Senior Member
All I did to replace mine was to take off the caliper, then i just hit the rotor with a rubber mallet to get it loose and it came right off.
Old Jun 5, 2003 | 09:30 AM
OicnaiC's Avatar
Damn , I'll have to keep an eye on 'em
bigjstang
Jun 2, 2025 03:56 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
CanRunner
Jul 20, 2015 01:29 PM
kvanzandt1
Jul 18, 2015 10:15 AM
