22re don't want to's
Old May 21, 2003 | 12:34 AM
david in germany's Avatar
Ok the time has come to swap the head.... before i bought my 4runner the idots that installed the rebuilt engine over torqued everything including the exhaust manafold studs (my big problem) i have used helicoil, didn't work used 12mm studs, they striped too (i actualy think this head has a defective in the metal)
so now i have decided to change the head.... I have a head but i still worry about my abilities to do this.
I think my concerns are the initial timing, and torqing everything to the correct spec. has anyone with low(not NO) mech skills accomplished this? what are some of the key things to worry about? I will be picking up a high quality torque wrench soon and i will be going with steel chain guides.
any recomedations on additional things to do with it torn down?
(at my skill level)
i have the chiltons.
David
Old May 22, 2003 | 12:19 PM
Hope this helps a little
Been there done that. try this link out for some It will get you in the right place anyway!!
Timing chain
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Nickdigg
Jul 7, 2015 06:04 AM
