tranny fluid flush
Old Oct 5, 2003 | 07:44 AM
rjm's Avatar
rjm
tranny fluid flush
getting ready to have the tranny flushed on my 02 tacoma,v-6,auto,4x4- will be swithcing to synthetic atf also- how many quarts do i need guys?? thanks
Old Oct 5, 2003 | 08:20 AM
Robinhood150's Avatar
About 14-15 quarts. I think you use atf for your transfer case so if you're going to change that too, then you should get a couple more. You're owners manual should say how much your transfer case needs.
Old Oct 5, 2003 | 10:17 AM
rjm's Avatar
rjm
tranny fluid
thanks- i have already done the transfer case(s) and diff
Old Oct 6, 2003 | 12:27 PM
Bob_98SR5's Avatar
The 4runner V6 3.4L engine takes 16 qts for a full ATF fluid exchange.
In the back of your owner's manual, check in the back where it says "Specifications" to verify the number above.
If you need Amsoil, send me a PM or email.
Thanks,
Bob
Old Oct 6, 2003 | 12:28 PM
rjm's Avatar
rjm
tranny fluid
thanks!!- i did check the manual- all i saw was the qty for drain and fill.
old87yota
Sep 9, 2015 12:39 PM
eggens
Sep 5, 2015 12:16 AM
Squigglez
Sep 4, 2015 07:33 AM
Scatterbrain
Sep 3, 2015 06:46 PM
pplusent
Sep 2, 2015 11:56 PM
