Rear Axel Seal Problems
Old Oct 2, 2003 | 02:43 AM
I bought a 1999 4 runner about 2 months ago. I noticed the drives side rear axel seal was leaking. I have changed the inner seal 3x and i cannon get it to stop. Fluid is still getting past it. I am very careful when I put the seal in and I use Toyota seals. Any suggestions?? It is driving me nuts. Oh and by the way I use synthetic oil in it as well.
Thanks for the help.
Brian:pat:
Old Oct 2, 2003 | 03:17 AM
Puddle Jumper's Avatar
I had a Dodge that was doing that and had it fixed under warrenty a few times, They also had to replace my brakes because the oil was ruining them. They never could stop it. I bought an aftermarket seal and put it in...no more leaks.
But I would also recomend not using the synthetic gear lube if your having a leak problem. If theres a scratch in you seal seat it will find it. You might have better luck with regular gear oil.
Old Oct 3, 2003 | 09:32 AM
Nobody's Avatar
Check out this thread
Hopefully there is new info you can use....
mskalmus
May 28, 2017 07:51 AM
icentropy
Jul 11, 2015 07:21 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
HRDC0R19
Jul 5, 2015 06:43 PM
