n00b oil change question
Old Sep 18, 2003 | 06:26 PM
CLin9383's Avatar
in an attempt to change my oil this weekend, i went out and bought an OEM yota oil filter. besides the oil filter, i find this lil washer inside with it..question is..what is it and where does it go? thanks in advance!
below is a very bad pic due to low light in my room..
PIC
Old Sep 18, 2003 | 06:37 PM
pigcake's Avatar
That's for your oil plug my fellow st louisan.
Old Sep 18, 2003 | 06:42 PM
CLin9383's Avatar
so that is the oil plug gasket mentioned in bobs writeup?? well dont i feel like an :ass: ....thank you fellow st.louisan
Old Sep 19, 2003 | 05:36 AM
jalaber's Avatar
Yes, its the oil plug gasket. You are supposed to change it with each oil change. But it does last longer than that. I did not know they were including them with the filters. I just received three from Conicelli, I should open them and see if I have the gaskets too.
Old Sep 19, 2003 | 09:46 AM
keisur's Avatar
I have never seen one of those in my oil filter boxes. I think my local stealer must be removing them so they can make you buy them. I have also never changed mine and I've never had any leaks or anything. going on maybe 50 oil changes on this thing too.
Old Sep 19, 2003 | 01:50 PM
pigcake's Avatar
That dealer is where I pick up my filters and I watched them open the box and drop it in there. I said, "thanks buddy".
Old Sep 19, 2003 | 02:10 PM
Yoter's Avatar
Guest
I wish all oil filter came with plug gaskets. Ineed to replace mine next LOF
Old Sep 19, 2003 | 08:51 PM
Toyo4x4's Avatar
I put a Fumoto valve on. No more drain plug and ring!
Old Sep 20, 2003 | 01:34 AM
Yoter's Avatar
Guest
What is it, where do i get it, how much?
Old Sep 20, 2003 | 01:47 AM
Tacoma Dude's Avatar
I put this in a little while ago at the same time I switched to Amsoil. I haven't changed the oil yet but I checked the cap after some salt water dousing at Pismo and the insides were all good
Old Sep 20, 2003 | 09:21 AM
Toyo4x4's Avatar
http://www.fumotovalve.com/ Go here for the prices and see whether you want the one w/ or w/o the nipple. I got the "nippleized" version so I can attach a tube to it for better draining accuracy onto a pan...not necessary though. They are very well made and I have never heard any complaints about them.
Old Sep 20, 2003 | 01:01 PM
keisur's Avatar
Walmart also sells that type of thing.
Old Sep 21, 2003 | 05:07 AM
evilcow's Avatar
Thats pretty cool but is it low profile? Will it scrape on a rock and leave a trail of motor oil in the forest?
Old Sep 21, 2003 | 08:57 AM
Toyo4x4's Avatar
Mine w/ the nipple sticks out about 2". The one w/o the nipple about 1.25". If you are a serious off roader and scrape over rocks and such, I would be leery about getting one.
Old Sep 21, 2003 | 04:03 PM
CLin9383's Avatar
well, i changed my oil yesterday and no oil plug gasket was on there, so i just left the one i got with the oil filter off. it took me almost 2 hours to do the whole change and the only reason was the stupid oil filter was REALLY tight on there. so i had to get my cousin to come and take me to get a oil filter wrench. other than that, no problem. i switched oils from mobile 1 10w-30 to 5w-30...hope it will be ok for winter here...again, i just wanted thank you guys for the support and feedback..it's always appreciated.
Old Sep 22, 2003 | 10:23 AM
pigcake's Avatar
I'm not sure about your truck but my oil plug is protected by the skid plate.
Old Sep 23, 2003 | 06:02 PM
evilcow's Avatar
Mine has a skid plate also. But if the plug is any longer than stock it could possibly scrape. I will just stick with using the rachet.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
horunner1x
Jul 10, 2015 06:33 AM
