PDA
View Full Version : Maintenance & Repair Archives
Pages : 1 [2] 3 4 5 6 7 8
  1. Air Conditioning Amplifier
  2. Fuel Filter Replacement: Compression Fitting Problems
  3. Know anythings about drive shafts?
  4. Please help....
  5. Brake problems on my 88 4runner
  6. Brake vibrations
  7. 1988 front driveshaft steering knuckle bearing tolerance?
  8. unbeleivable smog check, 3100 points over HC
  9. 86 Celica won't start
  10. starter suggestions
  11. Replacing spark plugs on 3.slow
  12. Differential or driveshaft?
  13. Diagram or list of the 3.4L pullys?
  14. P0121 - Throttle Pedal Switch Position Sensor
  15. Jumpy idle
  16. really hard to get into gear
  17. What does this mean?
  18. What oil for 100k+?
  19. Rusted Carriage Bolts for P/U box
  20. Gas Pedal Sticking
  21. Reading Ohm Meter????
  22. Tale light out in 91 4runner
  23. FLUID Exchange...
  24. Throttle position sensor problems...?
  25. no power after rebuild, timing?
  26. 22RE - Timing chain replacement estimate
  27. Throttle position sensor probs?
  28. Where to purchase parts?
  29. antenna broke
  30. Maintenance light
  31. "fluttering" noise from engine compartment
  32. Front Diff Prob
  33. Turning the rotors, dealer or outside shop ?
  34. Fuel Filter
  35. 22RE Valve Adjustment Question
  36. Timing issues on rebuild motor
  37. Tranny problems at 190kms??
  38. engine noise similar to blowout valve
  39. pickup clutch and shifter
  40. 01 Taco sits at angle..........
  41. leak on transfer case need help
  42. ABS Relay "inoperable"
  43. Help...Engine check light...codes P0441 & P0446
  44. Leak?
  45. just replaced plugs now it hesitates
  46. Inconsistent clutch
  47. Sway bar end links
  48. CEL Issue
  49. Oil leak help?!?!?!?
  50. Bouncy speedo needle
  51. Carbon Buildup?
  52. Too late to switch to Synthetic?
  53. Error Code 26
  54. CODE P0441 on 1997 4RUNNER SR5 3.4 LITER
  55. Write-Up: CV Axle Replacement for 3rd Gen 4R & Tacos
  56. minor problems no solutions
  57. Water under my dash: 04 Taco
  58. 2002 4Runner 2X4 Alignment Specs
  59. Charcoal Canister needs replaced at 65,000 miles?
  60. Code 22?
  61. Worst Day Ever! Broken 1st gen rear leaf!
  62. non starting woes........ end of long day.
  63. Help!!!! timing/vacuum????
  64. nasty sludge buildup in oil cooler coolant lines ????
  65. Diagnosing no 4WD lock-up
  66. where does this vaccum like go?
  67. 1990 210k miles tuneup n stuff?
  68. getting hot at 65
  69. fuel filter???
  70. P0172 Code on Check Engine Light
  71. Steering Rack Help!!! Need a favor!
  72. 3.0 EFI issues
  73. Help with CODES
  74. P0306
  75. vacum/intake or fuel problem??????
  76. Do the fans on the 3.4L's blow apart?
  77. Frozen Lower Control Arm Bolts
  78. Pin hole leak in ATF Cooler (URGENT)
  79. Code 52, Knock Sensor, Anyone fixed theirs?
  80. 1998 4Runner. Rear hatch dead. No wiper, no power window, license plate lights, etc..
  81. Another STARTING problem!!!!!!!!!!!!!!!
  82. Differential problems
  83. Rear drum brake questions.
  84. Relief valve?
  85. what tire shine?
  86. 3rd Generation Fuel Gauge Problem
  87. Flying saucers
  88. a/c compressor questions
  89. HELP check engine light code, *SEARCHED*
  90. Napa Clutch vs. Toyota Clutch (94 SR5 4x4)
  91. transmission
  92. Noisy Bearings or U-Joints
  93. O2 sensor studs. Replace-able or not?
  94. 3VZE 3.0 Cam seals
  95. Rear window dead on 98 SR5
  96. ps pump belt install issues
  97. HELP! I hooked my battery up backwards
  98. brake noise help
  99. No shine no slip interior cleaner
  100. Rack and pinion problem?
  101. Brake and bearing ?
  102. Difference between Amsoil ASF & SDF oil filters
  103. Holy dealership prices Batman!
  104. Does Anyone Have a Shock Recommendation?
  105. Creaking Noise on 2nd Gen 4runner
  106. 91 4runner problem
  107. Funky rattling noise under neath the steering...
  108. Automatic Transmission Question
  109. How to tell if a tire is F*&ed up
  110. Low compression
  111. question about wax
  112. Clutch pedal bracket replacement???
  113. Got headers? Check your nuts!
  114. I bet this is a new one!!!
  115. Damn brakes!
  116. 3.0 mpg & power woes
  117. de-chroming ?
  118. Too fast idle when cold HELP!!
  119. wheel bearings are shot...maybe..
  120. 3rd Member Swap
  121. COIL PACK REPLACEMENT 3.4 symptoms,slight skip,results, CHECK YOUR COIL PACKS TODAY
  122. Strange happenings....
  123. Please help, 3.0 running rough, no power etc.
  124. 1985 22re EFI Engine Sputtering!!!
  125. Best lube for Tranny/transfer & diffs????
  126. gate wont open on 98....
  127. problem with rear drum brakes
  128. Carb Fuel pump
  129. Gear Oil and Upholstery
  130. Steering Squeek
  131. Loud roar from rear-end when over 30-40 MPH and on the throttle.
  132. About how long will a rebuilt idler arm last?
  133. Check engine light reset?
  134. I want to get rid of the emissions crap...
  135. Fuel System Troubles
  136. ? about 3rd gen gas gauge
  137. ? about torque wrenches
  138. POR-15 and paint question
  139. Still Fighting 60+ mph vibration...Give me some possible mechanical causes PLEASE...
  140. 2nd time HG BLOWN, buy NEW motor @ only 130k or rebuild?
  141. 3rd gen Transfer case vibrations?
  142. Replace or rebuild idler arm?
  143. CEL Code PO420
  144. Cooling line question (pix)
  145. 30K Service
  146. Clay Bar.....Pics!
  147. Aftermarket Starters for 4Runners, thoughts?
  148. 1985 22re sputtering
  149. Rear Shackle Bushing Removal
  150. flywheel bolts suck
  151. need help w/transmission or driveline problem
  152. Finally got my truck back, but now I have MORE problems. HELP!!
  153. Switched to synthetics
  154. whats wrong with my 4runner...:(
  155. flashing o/d light and no speedo
  156. Problem w/ K&N Air Filter & X-Stream Flow, Please HELP!
  157. Problem found.. with my Aisins.....
  158. VSS location
  159. Horn not working? help please...
  160. Torsion Bar BOLT replacement
  161. Turns Over, but no dice.
  162. head gasket?
  163. Where is this located?
  164. What Diff. Oil do YOU use
  165. more aisin problems
  166. Problems with Aisin Hubs
  167. front brake pad/rotor recommendations
  168. Emergency please help...fuel hose
  169. bad brake cylinder
  170. Automatic trans. flywheel bolt-up
  171. Brake smell Is it normal?
  172. Belts Squeaking?
  173. Dropped Drive Axle doing 70!!
  174. How to reset "Maint Required" light?
  175. 1980 starting problems
  176. CEL 27?? O2 sensor voltage?
  177. 22RE timing problem
  178. What interaval do you guys think is OK with Mobil One?
  179. Head Bolt Retorque
  180. 86 4Runner idler arm
  181. Vaccum Help V6
  182. *HELP* - 3rd Gen - Loosen Driver's Side Mirror
  183. 1st Gen Runner - Water leak
  184. Engine problems
  185. Adjusting valves
  186. Amsoil Full Flow & Bypass install.
  187. Dupont Teflon Car Wax?
  188. engine knock
  189. 3VZE is supposed to run on 87 octane!
  190. Warn winch rebuild help
  191. 86 22re Fan clutch replacement
  192. Wheel Info Needed!!!
  193. Gas guage not working, please help
  194. Chassis parts: O.E. or Aftermarket?
  195. I thought replacing cv axle was easy...
  196. excellent idea for trans installation..
  197. cluch problems
  198. lowering truck back to stock height please help
  199. Rear tailgate window motor...
  200. throwout bearing grinding on pressure plate
  201. Code 51 & 52: Weird problems
  202. How do I know if cv axle is good/bad?
  203. Rebuild engine or not
  204. Is this mechanic right or wrong?
  205. S.S. brake line write up?
  206. where is my transmission fluid going???
  207. Clutch sticks to floor
  208. Clicking CV joint, repack or replace?
  209. Strange smell
  210. Interior air filter on a Tacoma?
  211. our new 97' 4Runner.. interesting noise. please help
  212. Steering Squeek
  213. Need Help Quick
  214. no clutch pedal
  215. Coolant leak
  216. Interior roof light dont work? $150+ to fix!?!?
  217. Cleaned and waxed the Runna
  218. My Truck is a Rusted HEAP!
  219. My first leak
  220. Tie rod ends
  221. Oil for a New 22RE
  222. GREAT NEWS GUYS! i blew my engine!
  223. Repacked bearings and First brake fluid flush
  224. What the thunk is this? (auto tranny question).
  225. CV Axle replacement on 2nd Gen?
  226. Need help finding a 22r carb part for a friend.
  227. SC'r tensioner pulley bearing: Should I replace it?
  228. Check your fan clutch!!
  229. 2nd gen over-heating
  230. fuel pump? or fuel filter?
  231. Stupid gas/oil leak on my seat!
  232. Front Driveline Noise
  233. Clank Clank under my 97
  234. Anyone tried POR-15 for Rust Proofing?
  235. broke a bolt Whats up with torque wrenches.
  236. Rear bumper all rusted...
  237. 3.4 V6 Engine Knock
  238. Gear box help
  239. Water pump
  240. clicking/buzzing from manual hub
  241. what could this rattling noise be
  242. Advise needed on head
  243. fuel filter (i searched)
  244. Starting Problems when Engine is Cold
  245. Maintenance on an inactive 4 Runner
  246. Problems when idling
  247. 3rd Generation 4Runner Fuel Filter
  248. water in intake
  249. 3rd gen overheating
  250. Rear Diff filled with Chocolate Milk??
