Carb Fuel pump
Old May 2, 2005 | 07:03 AM
yotanso-o's Avatar
Carb Fuel pump
To replace a 22re with a 22r would i need to replace the fuel pump?
thanks
Old May 2, 2005 | 07:19 AM
kyle_22r's Avatar
yes, the 22RE fuel pump is in the tank -- you'll probably need to swap the whole tank as the EFI and carbed tanks are different.
why are you downgrading though? if you blew up your 22RE and are installing a 22R, remember that you can swap your manifolds on to it and convert it to a 22RE with minimal effort.
Old May 2, 2005 | 07:32 AM
yotanso-o's Avatar
well actually, the truck i have was a 22rte, the previous owner put a 22r in and now i am trying to figure out what he had to do to switch it. so i can assume the fuel tank was removed from mine? the computer wouldnt have to be removed right? does the 22re have a different cam than the 22r? do you know if the 22rte had a diff computer than the 22re? thanks for your help
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
