lowering truck back to stock height please help
Old Apr 23, 2005 | 07:08 AM
slimb's Avatar
Question lowering truck back to stock height please help
well yota tech has never failed me for help so lets see if you awesome people can keep up? well yesturday i got pulled and got a altered suspension ticket his 36 inch yard stick didnt even touch the ground and frame at the same time and i can only be 28 inchs so i am dropping truck back to stock with 33's what do i need to buy in order to get my truck back down or can i just take the lift of or what? please help i did not put lift on so i dont know much about it? he also said my bumber wasnt stock so thats why he measured to the frame.
heres a pic of my truck
Old Apr 23, 2005 | 09:41 AM
Silver_Truck's Avatar
That sucks....you can just swap out your lift components with the stock ones....What state do you live in, sounds like a crappy law to me
Old Apr 23, 2005 | 09:48 AM
Paul H.'s Avatar
A picture of what lift you have would help.
Old Apr 23, 2005 | 10:28 AM
slimb's Avatar
i know nothing about the lift and no cam my dad is borrowing it. i live in va we have the dumbest laws. from what i was told the truck has a 4 inch lift if i take that off wont i still be 4 inchs illegal i am like 36 1/2 inchs and i can only be 28
Old Apr 23, 2005 | 10:31 AM
terryjmatthew's Avatar
Just from the picture, it appears that you have way more than four inches of lift.
Looks more like six or eight to me.
What size tires are on it?
Old Apr 23, 2005 | 10:34 AM
slimb's Avatar
33's i was told 4 but i dont know for sure
Old Apr 23, 2005 | 10:47 AM
jimbo74's Avatar
thats crap... the cop is wrong fight it... CA has some pretty NAZI laws and they have one like that as well... however according to the law itself to the letter the lowest part of a frame rail that runs the length of the body is where they are supposed to measure it from... oh and look at that, if those are 33s, then look @ where the framerails are between the tires... i bet that is 28" right there.....
Old Apr 23, 2005 | 01:53 PM
CynicX's Avatar
According to VA law: No person shall drive on a public highway any motor vehicle registered as a truck if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, do not fall within the limits specified herein for its gross vehicle weight rating category. The front bumper height of trucks whose gross vehicle weight ratings are 4,500 pounds or less shall be no less than 14 inches and no more than 28 inches, and their rear bumper height shall be no less than 14 inches and no more than 28 inches. The front bumper height of trucks whose gross vehicle weight ratings are 4,501 pounds to 7,500 pounds shall be no less than 14 inches and no more than 29 inches, and their rear bumper height shall be no less than 14 inches and no more than 30 inches. The front bumper height of trucks whose gross vehicle weight ratings are 7,501 pounds to 15,000 pounds shall be no less than 14 inches and no more than 30 inches, and their rear bumper height shall be no less than 14 inches and no more than 31 inches. Bumper height limitations contained in this section shall not apply to trucks with gross vehicle weight ratings in excess of 15,000 pounds. For the purpose of this section, "truck" includes pickup and panel trucks, and "gross vehicle weight ratings" means manufacturer's gross vehicle weight ratings established for that vehicle as indicated by a number, plate, sticker, decal, or other device affixed to the vehicle by its manufacturer.
Old Apr 23, 2005 | 03:50 PM
axon's Avatar
screw it....get it registered in another state, that is a state whos laws you meet. A friend used to get all kinds of tickets for his tint from the VA storm troopers, until he registered his truck in Flordia. Now thay cant touch him
Old Apr 23, 2005 | 04:42 PM
CynicX's Avatar
Yeah but to get tags for VA you need the vehicle to be regristered in VA right? I know you cant live in a state with tags from another state, learned that one the hard way....same with your license, another hard lesson heheh
Old Apr 23, 2005 | 08:44 PM
Robinhood150's Avatar
It sounds like you just need to lower the bumpers. Weld some steel to them.
Other than that, we need to know what type of lift you have on now. It's pretty obvious you have a body lift, but that doesn't do anything to the frame or bumper.
Old Apr 24, 2005 | 11:12 AM
4Crawler's Avatar
Front bumper may have been raised for the body lift. If so, remove the raising bracket and that would lower the front bumper. Rear appears to be a stock height bracket. You should be in the 4800# GVWR range with the truck (check the decal inside the door jamb), measure the heights yourself and adjust things as needed. For 33s, you do not need that much lift:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
You may be able to pull off the taller lift, and sell those parts for more than a milder lift would cost.
Old Apr 24, 2005 | 12:52 PM
slimb's Avatar
he measured the frame in the back he said that my bumper is not stock! wtf
Old Apr 24, 2005 | 01:02 PM
4Crawler's Avatar
Most frame height laws I have seen are to the "lowest" point of the frame. Almost all frame kick up higher in back and most are higher in the front as well. So the proper place to measure is in the center of the truck, where the frame is level and at it's lowest point.
I actually printed out a copy of the CA Vehicle Code on this section, carry it in my truck with a tape measure and know what/where to measure in case I am ever stopped and questioned on this. In CA, it makes a difference how your vehicle is registered as to what specs. you have to meet.
Old Apr 24, 2005 | 02:40 PM
rngrchad's Avatar
Slimb, that's rough man. Read into CynicX's post and figure out where your vehicle falls into the law. I would imagine there is a way around it. I once got pulled driving my old Chevy strictly because it was lifted. It's BS but just a fact of life...big trucks attract attention just like a bright yellow mustang. If it were me, I know what I would do.....pay the ticket and never lower the truck....but that's just my hard-headedness. Good luck with whatever you decide to do.....I would take off the Body Lift and leave it at that.
Old Apr 24, 2005 | 04:32 PM
runnerboy97's Avatar
where in VA do you live? i think that cop was really bored to go and pull out a yard stick and measure your truck. i drive my 884runner every now and then its on 37" tires, the lowest point on my frame which is the crossmember is 27" off the ground, way higher than yours, and ive never been hasseled. it think it all depends on where in VA you live.
if you read the law as stated in an above post it reads the height it to be measured to the bumpers.
Old Apr 25, 2005 | 12:31 PM
slimb's Avatar
i live in yorktown witch is like 30 miles from norfolk and va beach. it was a k-9 cop no bs a k-9 cop pulled me over a state tropper was behind him but never said a word and sat in his car 80 percent of the time. there was no reason for him to give me that ticket i was not rude at all very nice yes sir no sir sorry sir is all i said i mean it was a accdient i have had the truck for two months and just got it back on the road. he said my bumber wasnt stock but i have seen at 30 toyotas online and driving around in the last two days that have that same bumber
voiddweller
19
May 2, 2016 09:10 PM
live4soccer7
Sep 3, 2015 12:29 PM
Niameyrider
Jun 25, 2015 05:50 AM
UKMyers
Jul 1, 2002 01:59 PM
Yoda
7
Jun 22, 2002 07:14 AM
