whats wrong with my 4runner...:(
Old Apr 28, 2005 | 02:30 PM
linjy2's Avatar
ok so the problem started yesterday, but today it would not even turn over.
first i put the key in, when i turn it, it goes "click" and stop, yesterday i got lucky and it started.
today it just goes "click" and maybe once it almost turn overs but doesnt
dead battery i presume? or u think any other problem?
spark plug? grounding?
Old Apr 28, 2005 | 03:05 PM
terryjmatthew's Avatar
Engine locked up?
J/k
Probably just a dead battery. Take your battery to a parts store and have it tested.
If it's good, then look for loose or broken grounds or bad starter.
Have you tried to jump it off?
Old Apr 28, 2005 | 03:06 PM
kevin444's Avatar
Most likely the starter is about to go out.
Old Apr 28, 2005 | 03:08 PM
linjy2's Avatar
it turned over.
i checked my battery was good, i have the optima yellow top. imma redo my grounding. i probably kicked something loose.
how long would a starter last. i was thinking that too. i have 75k miles 1997 4runner limited.
Old Apr 28, 2005 | 03:09 PM
soarerjzz30's Avatar
Yeah I'd say it's your starter, I had a similar problem with my intergra it would click and if I kept trying to start it would eventually turn over.
Old Apr 28, 2005 | 03:10 PM
linjy2's Avatar
ahh...darn it, how much is a 4runner starter? anyone?
Old Apr 28, 2005 | 03:12 PM
you could probably get a used one for a good price, that's what I had to end up doing, had no problems after that.
Old Apr 28, 2005 | 03:26 PM
Robinhood150's Avatar
This is a very common problem. Try searching and you'll find a $10 solution.
Old Apr 28, 2005 | 03:52 PM
linjy2's Avatar
thanks robin. found the solution
i feel like such a noob...
maybe because i am, haha.
i'm so used to telling other people to use the search buttons on other boards.
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
