Code 22?
Old May 8, 2005 | 05:29 PM
rpeAMP's Avatar
Code 22?
Well my 92 4Runner has been throwing a CEL intermittantly for the past few weeks, and I just now got around to checking it.
Unless I'm reading it wrong, I think it's Code 22, which according to the chart is an Engine Temperature/Coolant Sensor. My radiator seems fine, and I have never had problems with temperature at all.
Any suggestions of what to replace? Where would this sensor be? My guess is that it's just gone bad, because I have no indication that I'm running too hot.
Old May 9, 2005 | 08:25 AM
DubJunkE's Avatar
Im pretty sure that sensor is located on the back of the motor near the firewall it's part of that metal housing with like 4 or more sensors coming out of it. If youre throwing codes intermittently it could be a loose/ corroded wire. Check those first but be careful because they get brittle and are thin so they break easily. I just broke 2 of mine replacing my motor so now Im trying to get that straightened out, Im also throwing the same code by the way on a '90 3.0.
Old May 17, 2005 | 07:23 PM
rpeAMP's Avatar
Hey thanks for the info. Sorry for the delayed response; I've been out of town.
Can you be more specific as to where to find it? Also, does anyone know anything about the importance/operation of this sensor?
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
