86 22re Fan clutch replacement
Old 04-24-2005, 05:18 PM
pruney81's Avatar
Does anyone have any tips on how to replace a fan clutch in an 86 4runner?
pruney81 is offline
Old 04-24-2005, 11:07 PM
Poopy's Avatar
Yeah, its easy . Unbolt the 4 bolt's on the water pump and the 3 for the fan shroud and lift them out as 1 piece. The 4 bolts are kinda tricky to get to and to make them easier to get to I would bump the starter to get the bolts where they were easiest to reach. To makes it easier I took off the top radiator hose as well.
Poopy is offline
Old 04-25-2005, 08:10 AM
wimpywade94's Avatar
or just get a 19mm socket on a breaker bar and turn the crank so you can get to each bolt easily with a 10mm open end wrench, the fun part is getting them back on!
wade
wimpywade94 is offline
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
coryc85
09-09-2015 06:24 AM
Kalihi,HI
07-09-2015 04:29 PM
zd92655
07-05-2015 04:25 PM
Quick Reply: 86 22re Fan clutch replacement
