1st Gen Runner - Water leak
Old Apr 25, 2005 | 10:22 AM
Extremesolo's Avatar
87 runner with a factory sunroof. When it rains the floor of the front passenger side gets damp. If I feel under the carpet the foam padding is wet. I have looked but have not seen anything obvious to cause this. Anyone else with a similar problem and where should I start looking to fix it?
Old Apr 25, 2005 | 10:38 AM
fnrunner's Avatar
Just recently noticed this too in my 89 Runner when I pulled the seats to put my wet okole's on... I pulled the front carpet too see if I could find the leak & haven't seen anything yet. Guess it hasn't been driven in enough rain?? If I don't find it soon, I was going to park over a water sprinkler to help locate it. BTW- mines on the pass. side too. Will post if I find something.
Old Apr 25, 2005 | 10:46 AM
93ToyKid's Avatar
On my 89 pickup, the a/c condensation drain tube had come off where it connects inside the cab, causing all the condensation to drain right down the firewall and under the carpet. Might want to check it to be sure.........
Old Apr 25, 2005 | 10:49 AM
I live in PA and it is not warm enough here yet to need the A/C. I read somewhere before that there is a drain for the sunroof that occasionally gets clogged but I have not seen anything like that.
Old Apr 25, 2005 | 11:07 AM
seaflea's Avatar
On the first gen runners, the windshield area rusts out. It is a bad problem with all of them I think. I had that problem too a couple of years back. after I pulled the windshield, I was able to see the problem. I repaired it, and havent had a problem since. Btw my sunroof has never had a leak. I guess I'm fortunate there.
Old Apr 25, 2005 | 11:39 AM
fnrunner's Avatar
Thanks for the ideas!
4x4-runner
Feb 26, 2017 06:42 AM
TACORICAN
Jul 6, 2015 04:44 PM
GorgeRunner
Jun 27, 2015 07:01 AM
chbarnha
Jun 18, 2015 10:23 AM
infinityisfive
Jun 16, 2015 06:51 PM
