- Spark plug wires,, aftermarket (autozone's best) OK?
- Brake Bleeding? The Answer?
- Owners of Auto tranny 4Runners
- belts on a 97 taco
- 4 Runner Heater Core removal?
- Schaeffers Oil
- Zaino'd my dad's Sequoia
- Tacoma Coolant Drain Plugs
- Clorox Clean-up on tires
- power steering pump replacement
- '00 4-Runner: 60,000 Mile Maintenance Time
- First Detail w/PC on '99 4Runner
- 60,000 maintenance, done
- how to set the distributer timing
- 2001 V6 4-Runner Air/Fuel Ratio Sensor location?
- new owner of 994runner
- power steering fluid
- wax over rust or ???
- 1st gen washer fluid question
- Brake pad life on 4th Gen
- Pure Power Lifetime Filter System
- URGENT! Clutch Problems
- Scratched windows...how do i get them out?
- Help... Clock and Front Right Speaker does not work!!!
- Reasonable OEM prices
- Cleaning the underbody of Shirley
- ANOTHER Bleeding Thread, SORRY!!!
- Timing belt and water pump change? Other maintenance?
- replacing belts on 87 runner
- First Tune - up
- Selling 4Runner but need new tires.
- exhaust
- Order of Bleeding Brakes
- What wax buffer do you use?
- Auto- RX or Amsoil Motor Flush
- How to change power steering fluid?
- toyota solid axle rebuild ????
- Power Steering Pump Bleeding....
- Thermostat replacement- 94 V6
- Engine cuts out and misses around 60mph.
- Idle loping/overheat/ problem
- 30K service and dual "tang" spark plug gap-
- Rack and Pinion Boot Replacement
- 02 TRD 4x4 Tacoma Tire pressure
- anyone who has changed a 3.4L timing belt
- Rear brake pad question
- idle jumpy and sluggish
- What kind of fluid goes into the ......
- 2003 4runner Manual on CD
- Best Plug Wires?!
- Which spark plugs for 3.4 Tacoma?
- Cloudy Headlights?
- 2000 4Runner Trailer hitch mounting bolts?
- Should I run synthetic motor oil?
- brake help!!!
- Time to check/change your coolant?
- Toyota Tacoma clutch Replacement
- Fina excel???
- Boots or whole CV axles?
- Boulder CO mechanic
- Switching to full Synthetics...Questions
- Oil Change Mishap
- LUCAS oil stabilizer.
- Here I go..........
- Adjusting Rear Drum Brakes - THE EASY WAY
- Mixing Trans fluid
- Ohhh Corey... :-)
- How much oil in 3.4's?
- a bad starting sound = no fun
- Transfer case fluid?
- AC leaks
- 22RE crank, rods trashed
- Power Steering - Loose Belt - squeaks
- 99 4runner - Tune up Questions
- how to check timing?
- whats a good tire pressure?
- new oil, pcv and fuel filter....
- Starter acting super odd!! help please!
- 4th gen air filter
- Fender Flare Gash Repair
- Changing Timing Belt on 93 4Runner
- 2nd Gen No power to rear glass wiper/washer/heater
- it's so purdy
- I found a downside to Amsoil...
- Locking Hubs cleaning Q?
- Removing bug residue
- Paint on top pf my paint
- Where is the MAF sensor
- Did I get ripped?????
- PCV Valve
- Wierd Discoloration on Glass - if you have kids....
- Do-It-Yourself Bedliners
- How to Get A Good Cleaning
- ? about detailing
- Griots cleaner wax?
- 22R dead?
- Plastic Cleaning?
- Rust
- HELP! My Porter-Cable went through to the primer!
- Looking for a Toyota mech. in Chicagoland area.
- part number for 3.4 oil filter?
- driveshaft center bearing went out, i think. please help.
- Recommended oils for high mileage engines
- Factory Service Manual for 1987 pickup?
- 3rd Gen Brake rotor problems
- Transmittion dip stick?
- Metal bits in rear diff
- cone washers on 88 yota truck
- toyota TIS
- 2 thumbs up for Sprayway glass cleaner
- Oxygen sensor replacement ?
- I Need Diagnosis Help: Ignition? Starter?
- anyone do painting??
- paint chip help
- HOLY SCHISTER!!! $500-$1500 waxes...Zymol Estate
- No Parking Lights
- Anyone tried Boeshield?
- Propeller shaft?
- 2nd gen brake pads
- Zaino observations
- Front Diff?
- Washing the truck.........
- Check Engine Code
- Clutch Slave Bolt Problems
- How to fix slow tire leak?
- Spark plug wire
- How many zerks and where on 4th gen
- Quick Help!! 1980 Toyota Wiring Diagrams!!
- Getting the 4Runner detailed
- Radiator capacity for 1996 V6 4WD 4 Runner
- Throttle Position Sensor
- Vaccuum lines
- Foam adhesive tape removal
- meguiar's trim detailer
- MAF Problem
- Just did my diffs and transfer case .
- replacing windshield
- MAF Sensor cleaning
- Overheating Problems
- Cleaning the interior
- Rotors...again
- Throttle Body Question
- '02 Ball joint lube?
- Bumper and Valence
- Waxing Roof
- Silicone instead of gasket?
- transmission fluid change
- bigger aftermarket oil filter
- My experience...Meguiars sucks!!! I'm going back to Zaino
- Removal of paint scratch on plastic side trim?
- Auto shops is NYC area
- 95 4runner oil questions
- Cleaning a MAF
- leaking p/s pump, rebuild or replace?
- Bosch windshield wipers - how do you get the stupid things off?
- Friend's 97 4Runner did not pass emissions test (Nitrogen Oxide) -- what's the cause?
- How to get oil into the diffirential ?
- Mr Clean Autodry?
- Airbags gone-What about my airbag light
- Quick question...
- 97 4Runner Paint Oxidation
- Moved: How to REPLACE power steering fluid?
- Power windows tip
- wiring order
- Anyone ever replace a 3rd gen blower motor?
- rear windshield wiper motor
- 2004 4.0L V-6, 4-Runner drain bolt torque?
- painting rims
- Royal Purple Oil....Anyone use it?
- will a wax compound work
- Rim Cleaner
- Old Oil Filters, Part # 90915-20001
- Front LCA bushing FSM...
- 1986 22rte Mass air flow sensor
- Where's the block drain plugs?
- 3.4L oil filter removal without the mess
- Changing wiper inserts
- removing tint
- Holy shiny tires Batman!
- 92 xtra cab 4x4 3.0 - Hard to start when warm
- 3.4 Oil Filter removal made easy :)
- best protection for your mechanicals
- How to Reset Maintenance light? 03 4Runner
- 22re problems........ Help!
- Corey, Chris
- Power Steering Fluid...
- WRITEUP- Lubing Your driveshaft
- oil change gotta love it
- thread on body work?
- maintenance light
- Depressurizing the fuel system?
- Highlander AWD AT Transfer Case
- differential fluid change
- Changing brake fluid
- help please
- Anyone use Meguiar's Color X?
- Been awhile since you've cleaned your carpet?
- CV joint repair.
- Mobil1 color
- Checking valves...
- The Starter Click Click Thanks for help
- need engine for '94 4runner
- Change your fuel filter... NOW
- need help removing cylinder head on 22re
- radio fuse ???
- Diff. plug size
- Help!!!!!
- Gapping plugs 101...
- Rotors...
- when to adjust valves?
- How important to get flywheel resurfaced when changine clutch??
- Hole in my carpet!
- Grill clip catastrophe
- Toyota sludge engines
- Coolant drain on a 2.7l block? Please help.
- Headlights Interchangeable??
- Griots Working It's Magic!
- Help! Rust on Seat-belt bottom point (steel ring????)
- Waterpump Woohs
- Rav4
- Changing trans & diff fluids
- molybdenum disulfide grease
- Shock installation question
- Starter replacement
- claybar tip
- BG 44K into intake??
- Tacoma filter change
- Ppwer Steering ???
- 3.4l timing belt replacment questions!!
- Head Gasket replacement procedure ?
- An alternate way of flushing the automatic transmission...comments please..
- What wheel claener do you use.
- Meguiar's NXT polymer wax
- tourqe converter service
- tranny swap
- Cost of Clutch Cylinder(s)
- What's your favorite tire pressure gauge?
- Clutch Bleeding
- Spark Plugs
- rack and pinion boot replacement....
- Service Bulletin Squeaky Dash
- "crush washers" question
- Oil pump to change diff oil
- Anyone use 15w40?
- NoVA GOOD dealerships
- Turned off the 3rd gen and the engine kept running
- Strap with cut off end
- exterior detailing questions
- Small nail in tire
