exhaust
Old Dec 7, 2004 | 05:38 PM
Lukeman82's Avatar
Question exhaust
alright then, here is what i invision for my exhaust on my truck when i can find a decent welding shop. header coming off the engine dumping into a side by side dual pipe all the way back into dual flowmasters, then dumping out behind the back wheel. does this seem retarded or am i on to something here.
Old Dec 7, 2004 | 05:48 PM
rimpainter.com's Avatar
Sounds like not enough back pressure to me. Stick with a single, 2" max.
Old Dec 7, 2004 | 07:37 PM
Lukeman82's Avatar
even if the pipes are 1 1/4" though? i just want something that sounds different
Old Dec 8, 2004 | 04:45 AM
Well, I am no engineer, but that still sounds like not enough back pressure for that engine. If you have to have duals, you may want to consider a single in dual out flowmaster (with very small outlet diameters). Or, a single all the way into dual out at the tip. You can do whatever you want, but I am just trying to save you the hassle of driving around at 5K RPM all day to get anywhere.
Old Dec 8, 2004 | 09:16 AM
kevin444's Avatar
I second that.
Old Dec 19, 2004 | 07:08 AM
CynicX's Avatar
......after the header you can get the most power w/o exhaust, the least amount of restriction after a tuned header will give you the best performance.....
reason i say this is because my wrx produced more power with the catback off the car (less backpressure) then with it installed (more backpressure)....it was only about 5hp and was on the same dyno day.....
of course it had alot of 3" pipe before that.....so i'm not exactly sure what the trick is...
Old Dec 19, 2004 | 06:44 PM
TACOMANATOR's Avatar
You will have no torque if you run a freeflow sytem like that on a 22r. As far as turbo charged vehicles--the less restriction the better. For N/A vehicles you need some back pressure. I can't understand why I see all these ricers with fart cans on their civics. They have no torque in their vehicles to begin with, then they have to put a fart can on it.
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
