power steering fluid
Old Dec 28, 2004 | 09:58 PM
kevin444's Avatar
can i just drain it out and put amsoil atf? Says so on the power steering cap. I always thought power steering fluid was its only type of fluid but since i saw it say use atf than it just threw me off.
Old Dec 28, 2004 | 11:29 PM
superjoe83's Avatar
i dont see a problem with your idea
Old Jan 8, 2005 | 09:23 AM
DH6twinotter's Avatar
Hey!
I always use Dextron III automatic tranny fluid in my PS pump. Not sure if the amsoil stuff would be ok, but I don't see why not.
Have fun all.
Daniel
Old Jan 20, 2005 | 02:10 PM
kevin444's Avatar
Does anyone know on a 3rd gen 3.4L. Which hose is the recirculation. Id like to perform a flush in some manner.
Old Jan 20, 2005 | 08:24 PM
superjoe83's Avatar
it will be the hose with just a spring clamp on it, the pressure hose will be crimped at the end, and have a banjo bolt holding it to the reservoir
Old Jan 20, 2005 | 10:03 PM
kevin444's Avatar
Thanks a bunch SUPAH JOE!.
Old Jan 26, 2005 | 07:15 PM
jethro's Avatar
OK I know this is probably a stupid question, but what exactly does the power steering fluid do for my truck? And what's going to happen if I don't change it.
Old Jan 26, 2005 | 08:44 PM
superjoe83's Avatar
THIS should help, if you don't change it your seals in the rack and pump may start leaking prematurely, and will cause excessive wear on the pump
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
