Clutch Bleeding
Old May 11, 2004 | 11:21 AM
4x4Lamm's Avatar
Clutch Bleeding
Could someone tell me where the clutch bleeder scrw is located and what size the screw is please? I need to bleed my clutch tonight.
Lamm
Old May 11, 2004 | 11:25 AM
eric-the-red's Avatar
Bleeder screw is on the slave cylinder, I don't remember the size offhand, but I would guess it's the same as the brake bleeder screws.
Old May 11, 2004 | 11:26 AM
4x4Lamm's Avatar
The slave cylinder is the one that is attached near the transmission right?
Old May 11, 2004 | 11:30 AM
Right, and the bleed screw looks just like the brake ones, should be next to the hydraulic line.
GRNTACO's Avatar
Mine is attached to the trans on the driver side and it is 10mm
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
