Transmittion dip stick?
Transmission dip stick?
Just brought a 2004runner SE V8 and realize I can't find the tranny fluid level dip stick and my friend had a V6 his is located near the engine oil dip stick. Anyone have a idea of where I can find that?
re: Dip stick
Originally Posted by Victor
I don't recall seeing one when I test drove a couple 2004's. Perhaps sealed at the factory?
This is remain an unknown subject.......what if i need to check the fluid level but the stick is not there May be it is sealed inside like you said.
In the 2004 model year, Toyota changed the fluid in the AT to a "WS" extended wear fluid. It is intended to never be changed or checked. Sounds strange, but here is the TSB that describes it.
R.
R.
Thanks so much for the info.
R.
R.
Thank you soooo much for this valueable information. I had contact 2 toyota service department for past few days. There technichans told me the same thing ----- As long as there is no leak in the system, there will be no need to check the fluid level. But I was haveing a doubt about that. Now the answer is right in front of me....... :pat:
Thanks again here for help me find the answer.
That's ridiculous, tranny fluid should be measured to make sure you have a correct level in there. Where is the fill plug on the tranny? If it's on the side of the housing, it might be just the same as a differential, where you unscrew the plug and feel if the level is up to the bottom of the plug hole.
Originally Posted by <<<<
There is no fill for V-8's sealed unit. One of the reasons why I did not buy V-8 is that "sealed" transmission.
What does the auto industry, especially Toyota, know about building stuff that lasts.
primordialbeast117
12-19-2015 12:23 PM
JookUpVandetti
09-30-2015 08:58 AM
