Transmittion dip stick?
Old Sep 13, 2004 | 10:57 AM
rliu007's Avatar
Transmission dip stick?
Just brought a 2004runner SE V8 and realize I can't find the tranny fluid level dip stick and my friend had a V6 his is located near the engine oil dip stick. Anyone have a idea of where I can find that?
Old Sep 16, 2004 | 07:44 AM
Victor's Avatar
I don't recall seeing one when I test drove a couple 2004's. Perhaps sealed at the factory?
Old Sep 16, 2004 | 08:06 AM
rliu007's Avatar
Question re: Dip stick
This is remain an unknown subject.......what if i need to check the fluid level but the stick is not there May be it is sealed inside like you said.
Old Sep 16, 2004 | 08:08 AM
TDiddy's Avatar
Just give your local delearship service dept. a call, they'll tell you one way or another!
Old Sep 16, 2004 | 08:09 AM
rliu007's Avatar
Wink re: Dip stick
Thanks so much..........
Old Sep 17, 2004 | 04:29 PM
wireless's Avatar
In the 2004 model year, Toyota changed the fluid in the AT to a "WS" extended wear fluid. It is intended to never be changed or checked. Sounds strange, but here is the TSB that describes it.
R.
File Type: pdf
Old Sep 17, 2004 | 06:29 PM
rliu007's Avatar
Thumbs up Thanks so much for the info.
R.
Thank you soooo much for this valueable information. I had contact 2 toyota service department for past few days. There technichans told me the same thing ----- As long as there is no leak in the system, there will be no need to check the fluid level. But I was haveing a doubt about that. Now the answer is right in front of me....... :pat:
Thanks again here for help me find the answer.
Old Sep 18, 2004 | 01:39 AM
Maddog's Avatar
isnt it annoying that you cant edit the thread title
Old Sep 18, 2004 | 09:13 PM
Mohamed's Avatar
That's ridiculous, tranny fluid should be measured to make sure you have a correct level in there. Where is the fill plug on the tranny? If it's on the side of the housing, it might be just the same as a differential, where you unscrew the plug and feel if the level is up to the bottom of the plug hole.
Old Sep 23, 2004 | 09:38 AM
<<<<'s Avatar
There is no fill for V-8's sealed unit. One of the reasons why I did not buy V-8 is that "sealed" transmission.
Old Sep 26, 2004 | 05:49 PM
TechWrench's Avatar
I don't have my manuals with me, (out of town), but there is a plug on the side of the trans case (sight plug) which is used to check the fluid level and add fluid if needed.
Old Sep 26, 2004 | 05:52 PM
TechWrench's Avatar
From what I understand, the '05 V6 will have an option for the 5 speed auto, so I would guess it will be the 'sealed' unit.
Old Oct 3, 2004 | 05:41 PM
4RUNR's Avatar
Guest
I don't buy anything that doesn't have solid rubber vulcanized tires.
What does the auto industry, especially Toyota, know about building stuff that lasts.
Old Oct 4, 2004 | 01:41 PM
<<<<'s Avatar
True, but takes some fun out of working on the truck.
primordialbeast117
Dec 19, 2015 12:23 PM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
irv
Sep 29, 2015 01:04 PM
yoterr
Sep 15, 2015 06:26 AM
