Shock installation question
Old May 29, 2004 | 06:24 AM
hatrabbit's Avatar
I am installing KYB front shocks on my '03 2wd, my question is about the dish shaped washers that surround the rubber bushings. Specifically, the center one... does it go over the lower bushing before the shock is fed thru the upper mounting hole, or does it go under the upper bushing?
Thanks.
Old May 29, 2004 | 08:17 AM
r0cky's Avatar
okay, can you take a picture of this so I can better understand to what you're referring? i've done a lot of work in the front, and I think I know what you are talking about, but I'm not sure if we're thinking of the same thing. How many dish shaped washers do you have? I believe I had 2 of them, and that one was larger than the other. Is this what you have as well?
Old May 29, 2004 | 01:20 PM
r0cky's Avatar
i looked at the link you posted (but your post isn't here anymore?!?), and i do think it is important that you install that middle washer ....
where did your post on here go though?
tj884Rdlx
Aug 28, 2015 12:04 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
rushw
Jul 18, 2015 01:46 PM
Massmayhem247
Jul 18, 2015 05:46 AM
Coreyr384
Jul 10, 2015 11:13 AM
