Engine cuts out and misses around 60mph.
Old Nov 27, 2004 | 07:42 PM
epic37311's Avatar
I got a carborated 22r with an airhog airfilter 4.10 gears . I just bought it about a month ago and run fine until last night, at high rpm it started cutting out and missing. If i put it neatural after reving it up it dies. If it was bad gas wouldnt it do it all the time? I dont have a tach so i dont know exact rpm range it starts missing at. I gave it a tune up about 3 weeks ago and it has run fine until now. I put splitfire plugs gapped at .32 new Autozone wires and changed the oil and air filter.Anything else i need to change? Any ideas why it would be cutting out? maybe the fuel filter?
Old Dec 17, 2004 | 09:56 AM
xenofuhrman's Avatar
Yes, its most likely the fuel filter. My old 87 just all of a sudden one day would cough and sputter whenever I was accelerating up a hill or jumping a stop light. Basically any time you are using a lot of fuel.
Just replace the fuel filter and you should be fine.
I forgot where it was, I think under the driver side by the frame rail...
Old Feb 4, 2005 | 04:07 PM
epic37311's Avatar
Stopped for a while now its back at it, but worse. Already changed fuel pump
Old Feb 4, 2005 | 06:30 PM
Ah yes, but did you replace the fuel filter. If its clogged, you could put a pressure washer on the other side and it would still only dribble out fuel.
Old Feb 4, 2005 | 06:56 PM
JoKEpLaYeR's Avatar
For a carburated fuel tank, is the filter on the pump or inline? On the EFI motors it's inline.
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
crashburnoveride
Jul 10, 2015 06:39 AM
akaphilly
Jul 9, 2015 02:34 PM
